Sponsored by BimmerWorld
Old 07-25-2014, 03:20 PM   #1
TheKingSim0n
My Ride: BMW 325i
Send a message via AIM to TheKingSim0n
Replacing Shocks
Im in need of new rear shocks for my 01 325ci and was wondering which shocks is recommended?
Keep in mind i live in NY
TheKingSim0n is offline   Reply With Quote
Old 07-26-2014, 01:35 PM   #2
kwake330xi
My Ride: 03 330xi
Koni yellows
I need rear shocks also, planning on goin with Koni yellows and Rogue RSMs. Has anyone done Koni yellows on the rear only, or do I really need to do fronts also at the same time to be worth it?
kwake330xi is offline   Reply With Quote
Old 07-27-2014, 08:26 AM   #3
djsilver
My Ride: '01 330Ci Vert
I put Koni FSD shocks on my wife's 330CI and we really like them. I'd recommend doing all 4 shocks to keep good balance and handling. www.shox.com
djsilver is offline   Reply With Quote
Old 07-29-2014, 12:10 AM   #4
The Thomas J
My Ride: 2002 325Cic
Do the springs as well. The stock sport springs are pricey but well worth it.
The Thomas J is offline   Reply With Quote
Old 07-29-2014, 07:21 AM   #5
drevilkep
My Ride: '01 330Ci 'vert
I just had the shocks replaced on my vert with Bilstein Tourings. A local BMW shop recommended to stay away from harsher shocks on the convertibles. They were getting complaints that the ride was too harsh and the car was too jiggly with the stiffer shocks. The Tourings are supposed to be a bit firmer than the stock sport package shocks. I like 'em.
drevilkep is offline   Reply With Quote
Old 07-29-2014, 01:44 PM   #6
TheKingSim0n
My Ride: BMW 325i
Im considering these as a cheap replacement, any reviews? http://www.ebay.com/itm/4-NEW-BMW-E4...p2054897.l4275
Old 07-29-2014, 09:29 PM   #7
The Thomas J
They will work ok. Change the springs as well. I can't stress that enough.
Old 08-02-2014, 09:40 PM   #8
TheKingSim0n
My Ride: BMW 325i
When you say springs your referring to the front shocks? or do both front and rear have springs?
Old 08-05-2014, 10:25 PM   #9
The Thomas J
The rear springs.
Old 02-01-2015, 05:53 PM   #10
stlhacker
My Ride: 2005 325CI
convertible upper shock mount
Anyone replacing rear shocks for the first time should be aware to disregard any instructions to remove interior panels from the trunk to access the upper mounts. The upper mounts on the convertible are underneath the toneau cover. Raise the cover and find to vinyl caps or covers on each side. Pop them out and you will find the upper mount nuts.
stlhacker is offline   Reply With Quote
Old 02-04-2015, 07:38 PM   #11
Archbid
My Ride: 2003 330cic
Why?
Archbid is online now   Reply With Quote
Old 02-04-2015, 07:39 PM   #12
Archbid
Doing this project on Saturday and you are officially my new best friend
Old 02-04-2015, 07:45 PM   #13
invisible man
My Ride: invisible car
Umm, no. No to those ebay struts (that are the wrong design and require modification) and no to changing your springs, that's completely unnecessary. You clearly don't have a clue what you're talking about.
Giubo. G I U bo. Pronounced joo-boh. Don't allow yourself to sound ignorant.
invisible man is offline   Reply With Quote
Old 02-05-2015, 01:09 AM   #14
The Thomas J
So enlighten us why changing the rear springs in unnecessary oh wise suspension guru.
Old 02-05-2015, 01:15 AM   #15
The Thomas J
Originally Posted by Archbid View Post
Why?
Why? Because you have a 12 year old car, regardless of miles they do wear out. I put new sport springs in my car in addition to all the other suspension work and it was worth it. The car handles and rides great!
If you are just doing shocks and what to be done with it than so be it. For me not to change the springs while I was doing mostly everything else on the car seemed foolish because they would have to be changed at some point.
Old 02-05-2015, 01:24 AM   #16
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
What the Hell are you talking about ? They are NOT the wrong design in any way.
They might be low quality, some might call them cheap; But they will fit just fine.
Bad information is like CANCER, "If you're unfamiliar with how these things work, it would be best you don't reply".
Seriously,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Rob43 is online now   Reply With Quote
Old 02-05-2015, 03:02 AM   #17
invisible man
I have personal experience with these exact struts. There is a tab welded to the strut where the little alignment pins are supposed to be. The welds won't fit past the opening and need to be ground away. The tab is also in the wrong spot and blocks the hole for the bolt. Then there is the problem of the extremely thin gauge metal these are made of. Running over rumble strips caused the strut to deform.
Old 02-05-2015, 03:04 AM   #18
invisible man
No. Springs don't wear out.
Old 02-05-2015, 03:21 AM   #19
invisible man
That's what's left of that little tab in order to get it to fit. And you can see the deformation on the right side. These struts are garbage. But go ahead and buy them, it's your money, but don't say you haven't been warned.
Old 02-05-2015, 03:23 AM   #20
invisible man
I'm sorry you're so offended Rob43 but that's not my problem either. I've done my research. Have you?
