Old 08-13-2014, 07:21 PM   #1
rocky46
My Ride: 2003 330i
2003 330i single 3in exhaust
has anyone done a single 3in exhaust on their car? I have headers,intake, im considering changing my exhaust to a 3in right after the headers. if I would run a single 3in I would just run one muffle since I like my car loud haha
rocky46 is offline   Reply With Quote
Old 08-13-2014, 07:32 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Yes, many have done this, it works very well.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 08-13-2014, 07:33 PM   #3
rocky46
My Ride: 2003 330i
also im doing this to save some weight and maybe make the exhaust flow better hence a little more hp
Old 08-13-2014, 07:34 PM   #4
rocky46
My Ride: 2003 330i
Good luck,
Rob43
does it make more power?
Old 08-13-2014, 07:36 PM   #5
rocky46
My Ride: 2003 330i
I also wanted a single exhaust to run a cat converter to pass smog. I know I wont pass the visual test but just to pass the check engine light test
Old 08-13-2014, 07:51 PM   #6
Rob43
Rob43's Avatar
If done right it does.
Rob43
Old 08-13-2014, 09:13 PM   #7
Sedan Hussein
My Ride: e46
What size is the spec e46 exhaust?
Sedan Hussein is offline   Reply With Quote
Old 08-13-2014, 10:48 PM   #8
Llink78
My Ride: 2002 330i
I have it on my 330i. Custom made merge stepped to the 3" SS pipe. Vibrant rez and a straight through vibrant muffler with a 3" section welded on for a "tip"
234HP/197TQ Just bolt ons :) New Numbers Coming Soon!
Llink78 is offline   Reply With Quote
Old 08-14-2014, 12:10 AM   #9
TrippinBimmer
My Ride: Just Fast!
Why does that look like my old 3" exhaust?
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 08-14-2014, 12:31 AM   #10
rocky46
My Ride: 2003 330i
Its dual 2in
Old 08-14-2014, 12:33 AM   #11
rocky46
My Ride: 2003 330i
How does it sound?
Old 08-14-2014, 10:21 AM   #12
Llink78
My Ride: 2002 330i
I wonder
Old 08-14-2014, 10:22 AM   #13
Llink78
My Ride: 2002 330i
How does it sound?
Deep, raspy, loud. All depending on what rpm I'm driving at
Old 08-14-2014, 03:34 PM   #14
rocky46
My Ride: 2003 330i
are you running any mufflers? or resonator?
Old 08-14-2014, 04:26 PM   #15
Llink78
My Ride: 2002 330i
Dude you quoted it asking. Vibrant res and straight through muffler. The pic shows both.
Old 08-14-2014, 04:56 PM   #16
Rob43
Rob43's Avatar
I thought that was a pic of a very long CAI.
Joking,
Rob43
Old 08-18-2014, 11:58 PM   #17
rocky46
My Ride: 2003 330i
Old 08-18-2014, 11:59 PM   #18
rocky46
My Ride: 2003 330i
3in header back with muffler and single tip. Sounds too quiet for me
Old 08-21-2014, 12:04 PM   #19
jared_wiesner
My Ride: 1999 328i (M54b30)
You're crazy, I can't get my 3 inch quiet enough for my liking. What muffler are you using? Is your tip resonated? Likely a straight through muffler and just a straight piece of pipe off the back as tip will wake it up some for you.
jared_wiesner is offline   Reply With Quote
Old 08-23-2014, 01:47 AM   #20
rocky46
My Ride: 2003 330i
Non reasonated tip. 3in inlet 3in outlet 4x9x14 straight thru muffler. Im using a magnaflow y pipe. Sounds good now broken in. Before my stock exhaust with a muffler delete was loud and a little drony,this setup is nice wen at WOT and deep sounding. No drone
