Possible "batwing" issue - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Old 08-25-2015, 07:29 PM   #1
jontizzle
My Ride: 2001 330ci
Exclamation Possible "batwing" issue
So at some point this summer I noticed the interior rear pillar trim is loose or broken. I haven't let the top down for months since here in Atlanta it's been way too hot. But with fall coming I want to fix it.
I read through this thread: http://forum.e46fanatics.com/showthread.php?t=520323
But I was wondering if anyone can confirm this is all I will need to fix it. I would hate to buy the wrong part(s) since I plan on vacationing next weekend. Any help/tips are much appreciated!
ID:	610576   Click image for larger version
ID:	610577   Click image for larger version
jontizzle is offline   Reply With Quote
Old 09-01-2015, 11:18 PM   #2
Phoenix330ci
My Ride: 04 330Ci Convertible
If the plastic triangular piece is broken or if the strings are broken then yes that is the correct thread and yes that will fix the problem. It is a good write up. I think the kit is around $135 bucks from the dealer. You might be able to find it a little cheaper, but pretty much a dealer item.
Tips, take a few pictures to make sure you understand how the threads go and how they bob and weave around the components. I have done this basically twice. One twice the strings broke and I tried first tie then together and then second use some like cordage and crimpy things to make a new cable to route around. Ultimately ended up just buying the kit and being done with it. (so I guess three times messing with it, once with a new kit.)
Another tip is removing the liner from the old wing, be careful here. Some people tore the liner trying to pull it apart. Just take your time and all will be well.
Phoenix330ci is offline   Reply With Quote
Old 09-01-2015, 11:28 PM   #3
jontizzle
My Ride: 2001 330ci
Thanks! I ordered the kit and will attempt to install it. Just wanted to make sure I had the right part and everything.
Sponsored Links
Advertisement
Old 09-02-2015, 12:01 AM   #4
Phoenix330ci
Yeah, that will take care of it. If you continue to operate the top with broken bat wings, they eventually get chewed up in the top mechanics and then can bind the system.
Just take your time, you will not get this done in like an hour so plan to spend some time on it. Only do one side at a time incase you need to refer to something on the other side. Some of the screws are in tight places and some time you will be switching tools often as one that works here and need to be shorter or flexible to work on another spot, and yes you will need to move the top up and down manually a few time to access everything.....read that write up a couple times. Not really that hard but time consuming.
Old 09-02-2015, 04:32 PM   #5
billeldon
My Ride: 2004 325Ci
This may be in my future, as soon as I have the free time. I bought mine in December 2014 with a small rip already showing in the headliner at the right batwing...
billeldon is offline   Reply With Quote
batwing, convertible, interior
