Shocks & Struts for 01 330i sport suspension (under $350) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 04-15-2016, 12:05 PM   #1
DLab330
My Ride: 01 330i
Hi all,
I'm looking for the best pick for replacing my factory shocks/struts with something OEM or better quality for under $350.
I was looking at the Bilstein B4, but I have some confusion if I can use them since I have the sport package, and want to reuse my stock springs.
Will the B4s work? Is there a better option for the sport package at a sub $350 level?
Thanks!!
DLab330 is offline   Reply With Quote
Old 04-15-2016, 02:49 PM   #2
Rob43
Suspension Guru
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
In this price range look at both the Billy B4 & the Koni Str.T on Forum Sponsor Tire Rack, if there's a "sport" option, choose that part number.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 04-15-2016, 05:47 PM   #3
ManOnTheCouch
My Ride: 330i
Part numbers for the sport b4's. Front left 22-139931. Front right 22-139948. Rear 19-103150. AJUSA has them for 285 shipped if you use the coupon code 5off4. Make sure to get new mounts too. Preferably lemforder.
ManOnTheCouch is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-16-2016, 02:35 PM   #4
DLab330
My Ride: 01 330i
Thanks guys, this is exactly what I was looking for!
I plan to do the job sometime in June. I'll make sure to update with how the installation goes, and what I think of the ride quality.
Old 08-29-2017, 12:11 AM   #5
DLab330
My Ride: 01 330i
Overdue, but I finally got around to installing the Bilstein sport b4s from AJUSA. I also installed new mounts and reinforcement plates both front and rear.
Wasn't too hard, and the car is much so smoother/quieter and easier to control in the corners! I had original struts/shocks with 160k on them. Definitely worth the upgrade! Thanks for your help!
Old 08-29-2017, 10:41 PM   #6
peleke4
My Ride: 2003 bmw 330ci
Hi DLab330,
I'm looking to do something similar: I have a 2003 330CI Coupe with 167,000 miles and original suspension still intact. I did replace the front control arm bushings recently though.
I want to replace suspension just like you. I'm going to get the following:
1) struts
2) shocks
3) mounts and reinforcement plates for both front and rears
Is there anything else you recommend that I buy? Thanks
peleke4 is offline   Reply With Quote
Old 08-30-2017, 11:57 AM   #7
RedOctober1984
My Ride: 2005 330i
I did this last summer. I did sport B4's, new mounts and reinforced mounts front and rear.
I went with the Rogue Engineering RSM's and they've been great. Couldn't be happier with the B4's either. Although if I ever replace them again, I'll either go to Koni yellows or Bilstein HD's.
RedOctober1984 is offline   Reply With Quote
Old 08-30-2017, 07:21 PM   #8
DLab330
My Ride: 01 330i
Originally Posted by peleke4 View Post
Hi DLab330,
1) struts
2) shocks
Hi,
If your swaybar links are in rough shape, it's a good time to replace those too, since they will be partial removed during the strut installation. Otherwise I think you're on the right path, GL
