Replacing front speakers - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BAVSOUND
Old 05-27-2017, 10:32 AM   #1
eglinton
My Ride: 318i e46
Hi. Im replacing the front speakers in my car. I have searced for the wiring diagram and colours but none match my car. My car has the mids in the door and tweeters up by the mirrors. Im not sure what wires are positive and negative. The tweeter wires are green and green and black. The right mid is blue and white with blue and brown. The left is blue and red with blue and brown. The wires from the tweeters plug in with the speaker plugs. So can i solder these wires together for the new speakers as they match up in the old speaker the green and black matches up to the blue and red and blue and white. Also which one is negative. From what i have found it seems that the brown is negative. Can someone please confirm.
eglinton is offline   Reply With Quote
Old 05-28-2017, 11:47 PM   #2
Hisdem
My Ride: 2004 M3 Convertible
I can't speak for the tweeters, but for the mid-bass speakers, if it's like my car was and like I suspect the standard is, the ones with the brown stripe are usually the negative wires.
Someone with more knowledge can confirm/deny this for you, but that's what my car was like. All negative wires had brown in them.
Hisdem is offline   Reply With Quote
Old 05-29-2017, 12:35 AM   #3
baders
My Ride: BMW 635 CSI S38B36
This is for Harmon Kardon.
Name:	Harmon Kardon pin out.gif
2002 E46 M3 Topaz Blue SMGII
baders is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-29-2017, 12:38 AM   #4
eglinton
My Ride: 318i e46
Thanks for the info guys. Baders i had already looked at that and the speaker colours do not match my car. My car has no amp and is a European model.
Old 05-29-2017, 12:47 AM   #5
baders
OK wasn't sure what you had. Failing a diagram, you can do a polarity test using a 9v battery and multimeter to ascertain polarity. Speakers don't care about positive and negative, as long as they all have the same polarity.
Old 05-29-2017, 01:07 AM   #6
nealfromnz
My Ride: 2002 e46
This approach with 9v battery can blow tweeters btw
nealfromnz is offline   Reply With Quote
Old 05-29-2017, 02:10 AM   #7
eglinton
My Ride: 318i e46
Hi nealfromnz. Any idea how i can test. Im quite sure brown is negative but the wires from the tweeters the black does not gonto the brown. This is what is misleading so the black from the tweeters go to one and the brown from the stereo go to the other
Old 05-29-2017, 03:35 AM   #8
baders
What year model is your 318 ? Go here for the appropriate Electrical Troubleshooting Manual; http://wedophones.com/Manuals/BMW/
Old 05-29-2017, 03:40 AM   #9
eglinton
My Ride: 318i e46
Thanks for that. Yes it is a 318.
Old 05-29-2017, 11:35 AM   #10
markusmarkus
My Ride: 2001 330Ci
Typically the wire with the brown stripe is the negative wire.
Old 05-30-2017, 05:21 AM   #11
baders
If you put details of your car in your sig it is helpful to those that wish to help you
Old 05-30-2017, 07:06 AM   #12
eglinton
My Ride: 318i e46
Hi baders. I think i have updated my car details. I thought i had done this but i must have missed it. Let me know if it shows up. Thanks
Old 05-30-2017, 07:07 AM   #13
nealfromnz
My Ride: 2002 e46
WDS is a system that gives wiring diagrams for older BMWs such as e46s. You put in your model like 318i and then you can find wiring diagrams for every element of your car including door wiring. WDS needs java and an adobe plug in on your web browser.
Failing that. The speakers will have either a red dot or a + symbol on the positive speaker terminal so just trace wire from speaker to plug.
Another option is to download an audio app for your mobile such as ones from Jl audio or audio control which uses a recording which you play and measure with your phone mic. This will tell you if the speakers are connected the right way around.
Otherwise, I do have a copy of WDS on an old pc here and can look up the wiring diagram tomorrow night ( didn't get a chance today )
Btw people are most likely correct on the brown stripe being negative on wiring.
Old 05-31-2017, 12:41 AM   #14
baders
Year man, what year ?
Old 05-31-2017, 12:49 AM   #15
eglinton
My Ride: 318i e46
Hi baders. The year of my car is a 2002. I have put the year in my car details i gave just looked and its says 2002 bmw 318i
Old 06-01-2017, 09:53 AM   #16
eglinton
My Ride: 318i e46
Hi nealfromnz. Did you manage to look at the wiring diagrams
Old 06-04-2017, 12:55 AM   #17
nealfromnz
My Ride: 2002 e46
From WDS assuming yours is a 2002 318 with 6 speakers
Name:	e46 6 speaker.JPG
ID:	656149   Click image for larger version
ID:	656150   Click image for larger version
Old 09-20-2017, 02:39 PM   #18
SimSimaz
My Ride: E46 '02
Well what do you know, just what I was looking for too. What brand did you use for your speakers?
Who's got the keys to my bimmer? Oh wait, I do.
SimSimaz is offline   Reply With Quote
Old 09-21-2017, 10:02 AM   #19
eglinton
My Ride: 318i e46
Hi. I used some sony speakers. Cant remember the model number. They are 3 way speakers 6.5 inch. I had to make some plates and packers but was a relatively easy install.
