AC no cold air - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Australia
Old 09-23-2017, 04:06 AM   #1
clartan
My Ride: 318i
AC no cold air
My AC suddenly stopped working. Initially it blows cold air on the passenger side and hot on drivers side. Today i had it regassed then all the vents are now not blowing any cold air. Fuses are confirmed ok, compressor is kicking in. The tech concluded that the compressor is 99% faulty because he's saying that even when he push the gas pedal, the high pressure is barely moving. I dont understand that hehe..
Im researching and read about the heater/water control valve. I'm not sure if that's the culprit or its really the compressor. I just dont want to spend money on replacing the compressor which is expensive, and turned out to be a cheaper part's fault.
Or would it be the Final Stage Resistor?
TIA!
clartan is offline   Reply With Quote
Old 09-24-2017, 01:32 AM   #2
glup
My Ride: BMW
If no airflow then its FSR - if no high pressure when AC running then yes most likely compressor has failed
Sent from my SM-G920I using E46Fanatics mobile app
glup is offline   Reply With Quote
Old 09-25-2017, 01:43 AM   #3
clartan
My Ride: 318i
It's blowing air but not cold. I'll have the compressor replaced. Thanks Glup!
