Sponsored by The Tire Rack
Old 07-15-2004, 10:05 AM   #1
lonnie_20
My Ride: 2001 Dinan 330ci
Send a message via Yahoo to lonnie_20
Question Rubbing
i have an 01 e46 coupe w/ 18" breyton visions...im running the 18x9.5 wheels w/ so3's(255/35) in the rear. i just installed the eibach pro system plus and am getting rubbing in the rear. i have already rolled the fenders, and still get a little rubbing...is there a "skinnier" tire size i could go with; or should i consider the 18x8.5 rear wheels?
lonnie_20 is offline   Reply With Quote
Old 07-15-2004, 11:08 AM   #2
Gary@Tirerack
Moderator
Gary@Tirerack's Avatar
My Ride: 1995 BMW M3
Most 245/35R18 tires can be mounted on 9.5" wheels, it just won't leave much protection for curbing of the wheels.
If they are hitting on the fender, you could try using a bit more negative camber in the alignment.
Refer to 'Gary/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by ordering through the sig link.
Click sig! -->
Gary@Tirerack is offline   Reply With Quote
Old 07-15-2004, 11:57 AM   #3
lonnie_20
any other options???
Old 07-15-2004, 11:58 AM   #4
lonnie_20
btw....they are 255/35 instead of 245....thanks for all the help
Old 07-15-2004, 12:35 PM   #5
Gary@Tirerack
Moderator
Yes, I'm aware they are 255/35. You asked if a skinnier tire could be mounted...thus 245/35...
Click sig! -->
Old 07-15-2004, 03:28 PM   #6
lonnie_20
my bad gary...long day!!!
