Bavarian Soundwerks' Mobile Electronics Forum
Have all your A/V and electronics questions answered here. Ipods, A/V, Radar Detectors Oh My! Sponsored by Bavarian Soundwerks |
#21 |
My Ride: C5 Z06 330i
properly matched (gain),
with no overdriving no x-over or EQ puere amplification in 1 volt out 2volts you can put a pyramid amp against any "SQ" car amp, and you will not be able to tell them apart, and if you think you can.... there is a guy that will give you $10K on the spot |
#22 | |
My US Amps will be operational long after the Pyramid dies...that's the difference. |
#23 |
build quality and longevity was never an issue,
sure some amps are built better than others, but this discussion was about sound quality not lifespan |
#24 |
OK, so you're saying if you put 3 different amps on the same set of speakers you wouldn't be able to tell a difference???
#25 | |
The difference is the build of the amp and its potential. At high volume, an overbuilt amp will not only last longer and play longer, it will still be able to accurately reproduce dynamic music passages without clipping. Pyramid amps can't. Last edited by bigjae1976; 09-25-2004 at 10:55 AM. |
#26 | |
properly matched, with no clippping, not likely, by ear of course, if you use an O-scope, of course you can plot a difference, a watt is a watt in any amp, same as a HP is HP in any car |
