Sponsored by The Tire Rack
Old 02-24-2005, 09:44 PM   #1
pimpn04coupe
pimpn04coupe's Avatar
My Ride: some hooptie
What kind of spacer is needed to make non-m e46 rims fit an e36 m3?
The guy that is going to buy my rims has an e36 m3, and i found out that my rims fit, but with a spacer. Does anyone know how big of a spacer he needs exactly to make it fit? Any help would be great the rims are
iforged aeros
19x 8.5 fr
19x 9.5 rr
e46 non m fitment...
pimpn04coupe is offline   Reply With Quote
Old 02-24-2005, 09:46 PM   #2
blurizpimpin
My Ride: 335i
Send a message via AIM to blurizpimpin
e36 m3 has same offset im pretty sure..
blurizpimpin is offline   Reply With Quote
Old 02-24-2005, 10:03 PM   #3
pimpn04coupe
no it doesnt, you know jack about offsets shadap eitene...
now anyone that actualy knwos about offsets can chime in?
e36 and e46 fit directly as i understand, but e36 m3 needs a spacer in the rear to fit regular e46 rims..
Old 02-24-2005, 10:16 PM   #4
crazy1323
My Ride: '02 330Ci
Send a message via AIM to crazy1323
well since e36 non-M's and M's have the same body i would say that they will fit an M3 without spacers if they fit a non-M without spacers.
'02 330Ci
A Bimmer, a Porsche, and an old Dodge, I am too lazy to list and update.
crazy1323 is offline   Reply With Quote
Old 02-24-2005, 10:26 PM   #5
pimpn04coupe
well i found out he would need a spacer from iforged directly, but he didnt tell me what kind of spacer, he just told me a small one. But now the buyer wants to know exactly what kind of spacer...
Old 02-25-2005, 05:51 PM   #6
330 HRE
Banned
My Ride: 330
its real hard to fit in 19x9.5 in an E36. If you put in spacers for that rim, you will need to roll and pull your rear fenders. My friend had 18x9 BBS RC Forged and he had to pull his fenders out to make it fit. I doubt those will fit on the E36 M without fender work of pulling. The offset to fit an E36 is anywhere from 35mm-43mm. 35mm you can only fit 235s in the rear with a fender roll and this is on 18x8 BBS LMs. Instead of asking here for an answer, its a E46 board....go to bimmerforums.com (mainly E36s there)
330 HRE is offline   Reply With Quote
Old 02-25-2005, 08:50 PM   #7
pimpn04coupe
really, that is really wierd because i thought the e36 m is wider than a regular e36. wow this is confusing, another guy at iforged said they will stick out an inch and iwll not fit!
Old 02-25-2005, 10:16 PM   #8
Antroiny
(\OO\ (||)(||) /OO/)
My Ride: 2005 ///M3
You can fit wider rims or rims with a more aggressive offset on an E46 than you can on an E36. The E36 fenders are not as generous as the E46. I can only imagine you'd need a spacer on the E36 to avoid rubbing the struts/shocks if your rims had a really high offset, but if you did that, you'd almost certainly be rubbing on the fenders really bad.
2005 Alpine White ///M3 SMG II
Antroiny is offline   Reply With Quote
