Sponsored by BAVSOUND
Old 10-22-2002, 03:37 PM   #1
Deejay77
My Ride: 325cic, Wrangler, R1
Send a message via AIM to Deejay77
Is stock speaker wire good for diamond audio hex components? I would like to keep x-o
x-overs in rear.
Deejay77 is offline   Reply With Quote
Old 10-22-2002, 05:14 PM   #2
theJrod
My Ride: X5-sold, 330i, WRX
Most people probably wouldn't be able to tell the difference between high quality speaker wire and stock BMW speaker wire. For front speakers that are probably getting only 50-100 watts, stock wire will be fine. For subs or anything with higher power/current needs, you'll want to upgrade the wire.
theJrod is offline   Reply With Quote
Old 10-22-2002, 07:03 PM   #3
djabaley
does anyone read my p0sts?
My Ride: 325 slushbox
Yeaaa! I've finally found a fellow Diamond fan. Don't use the factory speaker wire, and don't put the x-overs in the trunk. Trust me, you'll be much happier if you put the crossovers closer to the speakers. Sure, it might save you some hassle if you leave them in the trunk, but SQ wise there is a slight, but noticable, increase in quality if you put them closer to the speakers. Also, do yourself a favor and use upgraded wire. You'll decrease noice and have increased shielding ability.
djabaley is offline   Reply With Quote
Old 10-22-2002, 07:24 PM   #4
lilherc79
"DPErt-ASchnizA-*****"
My Ride: ASA ACS 3.0 Cabrio
I had the Hex's on my old ride. i just gotta say that they are one of the best sounding speakers out there. (if you tweak them the right way) Close to Focals! Far as the wires go, i'd rather lay out better wires though. cuz those things can take a lot of power.
lilherc79 is offline   Reply With Quote
Old 10-22-2002, 08:35 PM   #5
Deejay77
questiion for djabaley
What amp are you running to the hex's? Do you have any in the rear also? or just front doors?
Old 10-22-2002, 11:32 PM   #6
ACS Rob
pinoyfanatic
My Ride: This --->
I would do it right the first time...change the wires...
Oh...I'm also a Diamond fan!
ACS Rob is offline   Reply With Quote
Old 10-23-2002, 12:00 AM   #7
djabaley
Re: questiion for djabaley
I'm using their D5 300.2 to power two compenent sets in the front doors. I run their mid-line speakers as back fillers off a smaller amp.
Old 10-23-2002, 12:01 AM   #8
djabaley
another diamond fan! oh, I just can't handle this. hey, nice D7 in there by the way. if I wasn't so poor I'd get one too I'd also get rid of my CM3 woofers for your nicer ones
