Old 04-21-2004, 01:30 PM   #1
dillard
My Ride: 2004 M3 Cabrio
Yellow Oil Light
This may sound like a stupid question... which means it probably is...
What does the yellow oil light mean?
Mine comes on every once in awhile but goes off. I checked the oil and the level seems fine.
Any tips?
Proud owner of '04 M3 Convertible:
dillard is offline   Reply With Quote
Old 04-21-2004, 02:25 PM   #2
4open
My Ride: 04 330i performance
Re:oil light
Hey. they actually talk about the oil light in either the manual or service manual. check it out. if it comes on and goes out....that means you're about a quart low. otherwise, it means you need to change it. -O-
4open is offline   Reply With Quote
Old 04-21-2004, 07:05 PM   #3
notE46
Where am I?
My Ride: M Coupe
yellow oil light = oil level low
red = oil pressure low
add 1/4 of a quart and see if it goes away. also i find that many people do not check the oil level correctly. it should be checked when the engine is warm. after shutting of the engine on a level surface, wait 5mins then check the level. wipe off the initial reading, then put the stick back in.
'87 325iS Sold but not forgotten.
'08 MINI Cooper S Mellow Yellow
'00 M Coupe Dakar Duck
'02 330ia
notE46 is offline   Reply With Quote
Old 04-27-2004, 03:51 PM   #4
dillard
I added oil and the yellow light still comes on.
Does anyone know of any other reason for a yellow oil light other than oil level?
Does a yellow oil light leave a code on the OBC?
Old 04-27-2004, 08:42 PM   #5
notE46
Where am I?
My Ride: M Coupe
how much did you add? I know with the 330i I had to add a whole quart.
'02 330ia
Old 04-28-2004, 02:03 PM   #6
dillard
My dip-stick read ok (middle) and I still added a full quart.
I think it has something to do with manually re-setting my oil service interval.
I plan to swing by the dealer to ask their advice.
Old 04-29-2004, 10:18 PM   #7
323iguy
99 323 with a few dents
My Ride: 99 323i, 96 328conv.
Send a message via AIM to 323iguy
i
had the same problem. if your oil level is not low you need a new sensor. and by the way my manual says yellow means oil level at the minimum and to pull over righ thten and there
323iguy is offline   Reply With Quote
Old 06-25-2004, 11:14 AM   #8
dillard
Dealer suggested the same. New sensor installed was estimated at $800. I think I will live with the 5 sec oil light and watch my oil level closely.
Old 06-25-2004, 12:34 PM   #9
Dev
PSHOPWERKS
My Ride: Yellow Porsche GT2
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers)
Current Hate Level: 10 | Previous Hate Level: 9
The hatin' level on the E46Fanatics.com board.
Dev is offline   Reply With Quote
Old 06-25-2004, 08:55 PM   #10
XX
My Ride: '01BMW330Cic
every day, and almost every start up, my yellow oil light comes on for about 5 seconds. dipstick is fine.
$800 for a sensor? jhc!
ditto above, i'll live with the yellow light!
davidw
2001BMW330Cic
XX is offline   Reply With Quote
Old 06-26-2004, 01:33 PM   #11
323iguy
800?
WHAT? 800 $ ? thats insane find a good mechanic that isnt your dealer to do it. and just have them do it when you need your oil changed cuz they need to open the oil pan anyway to do it and get a new gasket it shouldnt be more than like 300 bucks for all that
Old 06-30-2004, 12:10 PM   #12
Surk01
My Ride: 99 Steel BluE46 328i
Oil light
Did all the pre-lim checks as you>>Had exactly same thing happening when I bought my e46 328... dealer replaced oil level sensor=fixed!! (yellow light)
Try sourcing the sensor aftermarket.... https://www.ultimatebmwparts.com/
imagine the mods $800 could buy you!!
Surk01 is offline   Reply With Quote
Old 08-05-2005, 02:11 PM   #13
vnspaceboy
My Ride: 330ci
Yellow Light!!
I got the same problem with my 330ci. The yellow oil light comes on once and awhile. I check my oil level every week. I still get the same problem.
vnspaceboy is offline   Reply With Quote
