Sponsored by The Tire Rack
Old 08-24-2005, 06:58 PM   #1
bmw3series
Banned
My Ride: ///M trizzle
What psi do you run on tires?
I do 40psi on each tire...what do you guys run?
bmw3series is offline   Reply With Quote
Old 08-24-2005, 07:37 PM   #2
MysticBlue2004
My Ride: 2004 330i zhp
I want to know too. Mine is ZHP with stock wheels/tires.
MysticBlue2004 is offline   Reply With Quote
Old 08-24-2005, 07:54 PM   #3
blackbmw330
My Ride: 2001 330ci
38 to 40
2001 330ci retired
blackbmw330 is offline   Reply With Quote
Old 08-24-2005, 08:23 PM   #4
kinggrimwood
My Ride: 1999 328i
it should say on the lable on the side of your door. or the side wall of your tires.
If you're not scared, you need to be driving Faster!
kinggrimwood is offline   Reply With Quote
Old 08-24-2005, 09:07 PM   #5
outalyne330i
My Ride: 2003 330i zhp
Send a message via AIM to outalyne330i
39 front/ 40 rear
outalyne330i is offline   Reply With Quote
Old 08-24-2005, 09:15 PM   #6
Keno
My Ride: 330ci + C6 GS
Send a message via AIM to Keno
46
Keno is offline   Reply With Quote
Old 08-24-2005, 09:21 PM   #7
tweeeker
My Ride: is getting modded
usually around 36......everyday driving in the east coast.
tweeeker is offline   Reply With Quote
Old 08-24-2005, 09:43 PM   #8
325 & 55
My Ride: 2001 325Ci Step
Recommended PSI....
You are correct in referring to the label in the Drivers door jamb for recommended PSI, however the psi noted on your tires Sidewall is the "maximum" tire inflation pressure
325 & 55 is offline   Reply With Quote
Old 08-24-2005, 10:38 PM   #9
TravsM3
TravsM3's Avatar
My Ride: 05' 545i, ZSP
Dude you aint no baller unless you got 35 psi
TravsM3 is offline   Reply With Quote
Old 08-24-2005, 10:43 PM   #10
dasblack
My Ride: M2
19" rims 38 psi's all around
dasblack is offline   Reply With Quote
Old 08-24-2005, 10:46 PM   #11
andyofyork
My Ride: 2000 323i 5spd
Send a message via AIM to andyofyork
18"s with 35-36 psi all around
They say there is a thin line between genius and insanity.
I say it is more like a Mobius Strip.
andyofyork is offline   Reply With Quote
Old 08-24-2005, 10:52 PM   #12
SnagD
My Ride: 2002 325i 5sp
Dude, put a little tint on the windows cool!
SnagD is offline   Reply With Quote
Old 08-24-2005, 10:55 PM   #13
kinggrimwood
My Ride: 1999 328i
Actually, it can vary from car to car and tire to tire. THe best way to find out what works best for YOUR car is to draw a chalk line on each tire. If the outside parts, or the center wear unevenly then you need to adjust your psi accordingly. the chalk line should wear evenly.
Makes sense, right?
