Can I run pwr off the HK upgrade amp? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BAVSOUND
Old 11-03-2002, 10:00 PM   #1
jaydc393
My Ride: 04 M3 Vert
Send a message via ICQ to jaydc393 Send a message via AIM to jaydc393
ok so I got the HK upgrade but I'm not happy with the bass, I have 2 12" rockfords but nothing to power them. I was thinking of using the HK amp if that was possible. does anyone know? would i be able to take the speaker wires off the HK subs and ptu them in my rockfords?
jaydc393 is offline   Reply With Quote
Old 11-03-2002, 10:04 PM   #2
lileccentricJ
My Ride: 2001 330Ci
Send a message via AIM to lileccentricJ
Not knowing the HK fuse size, I wouldn't suggest doing that. Why not just run fused power from the batt and ground to the chassis closest to your new amp? should be easy enough and IMO safer for blown fuses and power quality.
Edit - read that one wrong... must be late as far as using the HK amp to power your rocks... dunno that. You can always just try it and see but I doubt the HK amp has the power your looking for to drive those. BTW, when I had the HK sub down I noticed the speakers were stamped w/ 2 ohm... so u can compare w/ ur rocks.
Desperately seeking mod $$... sponsorships available! hehe
^ Please pay me to put your banner ad here!
lileccentricJ is offline   Reply With Quote
Old 11-04-2002, 12:05 AM   #3
dollar99
My Ride: c6 Z51
Send a message via AIM to dollar99
ummm.. I don't think the HK amp will supply suficient power. You are better off buying a 500.1 amp. Come on dude, you drive a BMW and can't afford a better amp?
2003 325ci (my first car) *Sold*
2004 Supercharged G35 coupe *Sold*
2001 Landrover Disco *Totalled*
2005 X3 3.0 *Daily Driver*
2006 C6 Z51 *needs FI*
dollar99 is offline   Reply With Quote
Old 11-04-2002, 04:38 PM   #4
jaydc393
My Ride: 04 M3 Vert
ok so looks like I'm gettin a new amp
so how would that work would I have to use the new amp to power all my speakers or just the Sub? how do I access the HK amp to replace it?
Old 11-04-2002, 11:16 PM   #5
lileccentricJ
My Ride: 2001 330Ci
This is kindda tough cuz I donít know your level of expertise or ability / desire to mess w/ wiring etc..
1) The HK main amp is behind the drivers side trunk trim. This Amp receives the inputs from the head unit, amplifies and distributes out to the speakers.
2) The HK Sub amp, this gets its input from the head unit (Iím not aware of it going to the main amp first) and there is a small black box (the sub amp) attached to the back of the black sub enclosure.
When installing an amp, you can get power form the battery, ground to the chassis and then either tap the HK sub unit for high level inputs or ask others here who might know how to get low level inputs for you.
In my case, I installed a powered Bazooka which has the amp in the sub enclosure. I just connected power and ground and tapped the HK subs. I wanted to leave the HK Subs as they have a higher frequency response than the Bazooka does and I didnít want to lose the punch. I hope this helps you understand the system a lil better.
