Old 11-01-2004, 11:35 AM   #1
BryanMonroe
My Ride: 328Ci
anyone replaced the alternator on their own? how difficult was it???
BryanMonroe is offline   Reply With Quote
Old 11-01-2004, 12:24 PM   #2
vinnymac
St. Louis BMW Fanatic
My Ride: 2011 335is
Send a message via AIM to vinnymac
It's not difficult but you will need the correct tools to take off the fan and belts.
I'd suggest replacing your pullies, tensioners, and belts while you are at it. You can get everything at www.bimmerzone.com or www.bimmerparts.com
vinnymac is offline   Reply With Quote
Old 11-01-2004, 01:04 PM   #3
niL
is on da floor
niL's Avatar
My Ride: 2001 330i
Send a message via AIM to niL
easy. did it without jacking the car up. just took my intake out and moved my power steering resivor for some clearance removed my belt's and loosend the 2 (or 3, cant remember) bolts holding it in. and the plug.
2001 330i rebuilt from the salvage yard
From start to finish...
niL is offline   Reply With Quote
Old 10-24-2005, 09:45 AM   #4
sp330i
Go fast Daddy!
My Ride: 330i
How do I know to use a 90 Amp or 120 Amp unit?
How do I determine which to use?
sp330i is offline   Reply With Quote
Old 10-24-2005, 11:39 AM   #5
ca1242
My Ride: 2003 330i
I think most us-spec cars come with the 120A model. It is relatively easy to get to the alternator's label to see what you have. If you do have a 90A and are doing aftermarket stereo upgrades, then definitely get the 120A one.
