From Auto-X to Trackday to Racing and Professional Motorsports – this is the place to discuss making BMWs fast
Old 12-11-2005, 09:59 PM   #1
Colebob
My Ride: 2001 330i
Autocross wheels for D Stock - Kosei
Hi,
I have a 2001 330i and would like to get a set of Kosei K-1 lightweight wheels for autocross (I have to retain the stock sizes 17 x 7.5 front and 17 x 8.5 rear). Do you know if they come in these sizes for my car and/or where I could get a set?
thanks,
Colebob
Colebob is offline   Reply With Quote
Old 12-11-2005, 10:01 PM   #2
MrMotorwerk
Der Meisterstück
MrMotorwerk's Avatar
My Ride: '02 330Ci,'01 M3,M4
not sure about the wheel widths, but TireRack carries those wheels.
MrMotorwerk is offline   Reply With Quote
Old 12-12-2005, 01:21 AM   #3
vaio76109
My Ride: Race Cars
Kosei K1's only come in 17" x 8.5"
vaio76109 is offline   Reply With Quote
Old 12-12-2005, 01:32 AM   #4
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
Believe it or not, they did come in 17X9 a while back. Good for mounting extra while slicks!
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
Old 12-12-2005, 01:40 AM   #5
Colebob
My Ride: 2001 330i
Thanks. If they only come in 17 x 8.5 then what would you suggest for the fronts? I had also heard you could get the K-1s in "blanks" and they could be made to fit?
Old 12-12-2005, 01:52 AM   #6
vaio76109
My Ride: Race Cars
"Blanks" is in regards to the bolt pattern.
Old 12-12-2005, 08:03 AM   #7
teamdfl
Slow in, slower out
My Ride: 325it
Originally Posted by Colebob
Hi,
thanks,
Colebob
If you are running in SCCA Stock (DS?), you need to run the same width wheel as stock and the offset cannot vary more than 1/4" (6mm) from stock. Your stock wheel sizes are 17x7.5 et41 and 17x8.5 et50. I'm fairly sure that there is a 17x7.5 et35 blank which will be legal up front (41mm - 6mm = 35mm) but I don't know what 17x8.5 blanks are available. E-mail Gary at the Tire Rack directly to find out.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
