Old 01-16-2006, 10:30 PM   #1
Obioban
My Ride: 05 M3, 01 M5, M3iT
Send a message via AIM to Obioban
HELP! Need a wire I can tap (for relay) only when xenon highs are on
Anyone know where one is in the car?
-Ian
Current Cars: 2005 IR/IR M3, 2001 LMB/blk M5, Wife's 6mt NA RWD e91, 04 M3 wagon
Past cars: 04 M3, 96 M3, S50B32 e36 M3 CM race car
"People do not see good design." -- Claus Luthe, BMW chief designer e30-e39
Obioban is offline   Reply With Quote
Old 01-16-2006, 10:37 PM   #2
bimmer07
Banned
bimmer07's Avatar
My Ride: //////////M
Send a message via AIM to bimmer07
Are you trying to wire your garage door opener to your high beams. Do you have xenon high beams i don't think they make them cause it takes a few seconds for it to reach the right brightness.
bimmer07 is offline   Reply With Quote
Old 01-16-2006, 10:47 PM   #3
Obioban
no, I want to make my halogen highs (inner bulbs) come on with my xenon highs (outer bulbs). I'm going to wire a relay but I need something to trigger it off of.
-Ian
Old 01-17-2006, 11:11 AM   #4
Speeder
My Ride: '04 325i - '08 C300
Check this thread:
http://forum.e46fanatics.com/showthr...ghlight=garage
Post # 19 might tell you which wire to use...
Speeder is offline   Reply With Quote
Old 01-17-2006, 11:25 AM   #5
Obioban
nope, that just tells me which powers the headlights, which I already knew.
-Ian
Old 01-17-2006, 12:54 PM   #6
Canuck328i
My Ride: 09 Altima Cpe
Sounds like you need to tap to the bi-xenon shuuter trigger. My xenons were a retrofit so I can't tell you the wire colour, but you are looking for the center pin of the smaller three pin connector going into the OEM ballast (this controls the shutter mechanism. It is positive trigger and should work fine with an extra relay load, but be sure to reverse-diode the relay to prevent spikes.
BTW this is the way I wired my high beam setup and it works great. Only problem is I believe you will loose flash-to-pass unless you get a bit creative with diodes.
Mark
Canuck328i is offline   Reply With Quote
Old 01-18-2006, 11:20 PM   #7
nEVERCLEAR
My Ride: 323
http://www.bimmerfest.com/forums/showthread.php?t=46813
http://forum.e46fanatics.com/showthread.php?t=296547
Thinking about a Honda or VW Dont buy from East Coast Honda - VW Read about my experience here
Some people dream of speed-others create a damn jet powered shopping cart.
Curious about VoIP and Vonage click here
nEVERCLEAR is offline   Reply With Quote
Old 01-18-2006, 11:22 PM   #8
nEVERCLEAR
My Ride: 323
Mark
If you just tap the high beam wires you don't lose the flash to pass. Mine is wired to that the shutters are only active if the xenons are powered. So if the headlights are DRL only the flash to pass works as it normally would.
