Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 03-27-2006, 12:31 PM   #1
'busa
'busa's Avatar
My Ride: E90 335i (sold)
Question 200 hour 'wear-in' period for plasmas??
I heard something about a 200 hour 'wear-in' period where the phosphors burn brighter in the beginning (?) and the TV should be set to a little darker setting during this period. I also heard that the plasmas are more burn-in prone in the first 100-200 hours.
I got a Panasonic TH-42PX60U a few days ago. It's a 9th generation plasma Panasonic display. Should I be worried about any of this stuff? What do you make of this?
PS: Sorry if it's a stupid question. As much as I researched this, it's hard to find a definite answer online, and from my experience with Bimmer advice, this forum usually knows best (well... knows pretty good).
'busa is offline   Reply With Quote
Old 03-27-2006, 01:08 PM   #2
Chase265
Suck it easy.............
My Ride: A BIG POS
Send a message via AIM to Chase265
its 100 to 200 hours that you are suppose to break-in the plasma....
here's a link to a dvd/vcd that you can download and burn which helps in the break-in process.
http://www.avsforum.com/avs-vb/showthread.php?t=583089
Chase265 is offline   Reply With Quote
Old 03-27-2006, 01:11 PM   #3
cleanaudi
My Ride: 04 330CI
Yes, you want to break it in, you need to lower the contrast/brightness settings etc. In addition, the link Chase265 posted is exactly what I would of linked as well, run that CD in your dvd player for 200 hrs minimum.. Otherwise, youll have image retention after about 5 minutes of a static image. Head over to the AVS forums and see what the specific settings are for break in for your unit. Im at 140hrs right now Another 860 hrs left for me (breaking it in for 1000 hrs)
Previous: E46 330ci
Current ride:
E92 335i Coupe: Alpine White with Black / Sport Package / Premium Package / iDrive / PDC / 6spd Manual / Brushed Aluminum.
cleanaudi is offline   Reply With Quote
Old 03-27-2006, 05:02 PM   #4
'busa
'busa's Avatar
Isn't that a bit much?
Old 03-27-2006, 05:21 PM   #5
'busa
'busa's Avatar
http://www.avsforum.com/avs-vb/showt...&&#post3551356 This seems related as well.
Old 03-27-2006, 06:34 PM   #6
'busa
'busa's Avatar
Where can I find that info?
Old 03-27-2006, 07:21 PM   #7
'busa
'busa's Avatar
Fourth, consider every technology in the market. I've been down on plasma sets in the past, mainly because they cost too much in high-definition models (those under-$3,000 sets all top out at a 480-line enhanced-definition resolution). But true HD plasmas are now starting to come down to Earth, while manufacturers say they've addressed burn-in and lifespan issues. Panasonic, for example, says the phosphor chemicals on its latest models now eliminate the need for a break-in period of restrained use (yes, just like on a new car) that some plasma experts once recommended. Across the board, 60,000-hour lifespans (enough for, manufacturers say, 25 years of viewing) are now the usual instead of 30,000 hours.
Old 03-28-2006, 03:26 AM   #8
cleanaudi
My Ride: 04 330CI
go to the offical panansonic post on the plasma forum
Previous: E46 330ci
Current ride:
Old 03-28-2006, 09:58 PM   #9
'busa
'busa's Avatar
Thanks for the referral. The only problem with that site is that it may have too much information.
Anyone have burn-in/image retention issues here?
Old 03-29-2006, 02:17 AM   #10
cleanaudi
My Ride: 04 330CI
true, there is a wealth of information on the site.. and yes, i myself had some retention, someone in the family used the tv for a few minutes with a static image and i had retention.. ran the dvd for 5minutes and it was gone
Previous: E46 330ci
Current ride:
Old 03-29-2006, 02:19 AM   #11
'busa
'busa's Avatar
Few minutes was enough? What model do you have?
Old 03-30-2006, 02:57 AM   #12
cleanaudi
My Ride: 04 330CI
Pioneer Elite 1130-HD
Previous: E46 330ci
Current ride:
Old 03-30-2006, 07:32 AM   #13
'busa
'busa's Avatar
Old 03-30-2006, 01:07 PM   #14
oie77
My Ride: wamta
I just picked up a 42" Hitachi plasma and am curious about this as well. Both the contrast and brightness are turned down to around 50%. Is that not enough? 1000 hrs of break-in seems like a bit much ... Did anybody else use the breakin cd from AV forums? Thanks.
oie77 is offline   Reply With Quote
Old 03-30-2006, 02:20 PM   #15
'busa
'busa's Avatar
I burned both the SVCD and DVD. Currently I'm using the DVD and I'm at about 60 hours. They say that for my TV, the first 100 hours are critical, and the remaining 900 one should not be exactly careless about either. I got about 60 hours of 70% break-in dvd and 30% watching tv on low settings in full screen so far...
Old 03-30-2006, 03:08 PM   #16
cleanaudi
My Ride: 04 330CI
Which DVD? Use Evangelo1's SVCD, its the most regarded one out there
Previous: E46 330ci
Current ride:
Old 03-30-2006, 03:12 PM   #17
'busa
'busa's Avatar
http://www.dvdshrink.info/goodies.php#run-in That's the other one I burned...
Old 03-30-2006, 08:26 PM   #18
Civin
My Ride: '03 330ci
Send a message via AIM to Civin
I've got one of the new Panasonic 42"s.. It has 0 problems. I have yet to see burn in regardless of what has been on it
2003 330ci Steptronic... .. .
Homepage . The Shiny Swine... .. .
Civin is offline   Reply With Quote
Old 03-30-2006, 08:39 PM   #19
'busa
'busa's Avatar
^ What model? Same as mine? How long have you had it?
