Sponsored by The Tire Rack
Old 04-07-2006, 05:26 PM   #1
black323i
My Ride: 323i
bbs rx fitment
hi all,
i just purchased a 2000 323i. i have found a set of bbs rx wheels from an e36 m3. They are 17x8 up front and 17x9 in the rear. The offsets are 38 and 32, respectively. will these work on my car?
thanx for the help
black323i is offline   Reply With Quote
Old 04-07-2006, 05:33 PM   #2
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
17X9 with 32mm offset may need some fender lip rolling on the sedan. It would have also probably been needed to fit an E36M3.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 04-07-2006, 05:46 PM   #3
black323i
My Ride: 323i
thanx gary!!!
where would i get a fender rolling done? are they expensive?
thanx for all ur help =)
Old 04-07-2006, 06:01 PM   #4
black323i
My Ride: 323i
after searching around, it doesn't look like rolling is too big a deal, but one last concern... the roll i may need isn't excessive or anything right? it wouldn't be a big deal?
sorry i'm completely unknowledgeable on this topic
thanx for any help
Old 04-08-2006, 08:55 AM   #5
Rudy@Tirerack
Moderator
Should not be a problem. This is probably the most common body modification that I can think of.
Old 04-08-2006, 01:38 PM   #6
black323i
My Ride: 323i
thanx a bunch =)
Old 04-08-2006, 03:00 PM   #7
LaShaniqua
My Ride: 325
Originally Posted by black323i
thanx gary!!!
what's fender rolling ?
sorry, n00b here
LaShaniqua is offline   Reply With Quote
Old 04-08-2006, 05:29 PM   #8
Qshio3000
My Ride: 2003 330i
sorry, n00b here
If you look inside the wheel well, you will see ~1/4-1/2" of metal sitting at around a 90 degree angle from the plane of the outer body;this can rub the tire if you are running large wheels and tires. When you roll the fender, you basically tuck that bit of metal up, thus gaining a certain amount of added space for the wheel/tire combo.
What a crappy explanation on my part. If anyone has a before-and-after set of pics, it might be clearer.
Qshio3000 is offline   Reply With Quote
Old 04-09-2006, 12:17 PM   #9
black323i
My Ride: 323i
made sense to me
thanx
