Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now! |
#1 |
My Ride: 04' 320i, 03' 745Li
Can I use a car sub as a home theater sub?
Hi guys,
My secondary Home Theater sub blew out...its actually been a while... I have a 12" Infinity car sub sitting around collecting dust...Im wondering, can I use that as my home theater sub? The only thing is, the actual HT sub I had, had a lot of knobs and stuff at the back to control sound output....and I think it had a built in amp as well.... Hmm...will my reciever be able to power the Infinity sub on its own?
#2 | |
Most likely, no...
Most receivers can only drive 6-8 ohm speakers. Chances are... your infinity sub is either wired for 4 or 2 ohm. Quote:
#3 |
http://forum.e46fanatics.com/showthr...t=home+theater
This might help you
![]() *Sig courtesy of ArjunGFX* |
#4 |
Yes you can use a car sub. You'll need a separate amp. Here is a link to some good cheap plate amps for subs: http://www.partsexpress.com/webpage....up_ID=505&SO=2
Most of those should have no problem with a 4 ohm sub. If you have dual 2, 3 or 4 ohm voicecoils, make sure to wire them in series. |
#5 | |
Thanks brew
#6 | |
