Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 07-17-2006, 10:11 AM   #1
Devonjordan
My Ride: e46 325i
e30 Project
Im looking to get my cousins 318 convertible, as a funcar/project car. The only problem is its got what amounts to 3000+ in repairs.
If any of you guys know e30's help me put these crazy prices into perspective. I feel confident that i can do most of the repairs, but maybe not without help.
-The car needs a new clutch, parts + labor was quoted at $1850, and this includes the flywheel surface. This was the diagnosis for that 'squealing' noise I mentioned that the car makes when the clutch pedal is depressed.
-The Idling problem I mentioned they said is due to it needing new Air Hoses. The hoses they said are cracked and it's not regulating the air flow properly. Parts & Laborwas estimated at $320.
-They also told me that the rear brakes need some work due to wear, parts & labor estimated at $443.
-Then there's the converty top- I took it to a place that only does tops, and they gave me an estimate parts & labor of about another $1600.
Found air boot from air flow meter to throttle body was cracked. This provides umetered air to the engine. That can cause engine to die. The air hoses to the pcv and the icv are also cracked. Reccomend replace all the air hoses."
"The clutch throw out bearing is making the screeching noise. Reccomend to replace the clutch."
These repairs cant really be that hard with a bentley manual and a good set of tools right?
Thanks for any help you can give me guys,
Devon
Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
Devonjordan is offline   Reply With Quote
Old 07-17-2006, 01:01 PM   #2
Devonjordan
My Ride: e46 325i
THERES E30 GUYS OUT THERE, I KNOW IT.
<---- HAHAHA 420, for all you potheads out there
Uh-Oh, thread failure
Old 07-17-2006, 04:23 PM   #3
rking
My Ride: E30 318i
Send a message via MSN to rking
my ride is under construction..... its an E30 though...
rking is offline   Reply With Quote
Old 07-17-2006, 04:56 PM   #4
Devonjordan
My Ride: e46 325i
Whats funny?
Old 07-17-2006, 08:46 PM   #5
Transporter99
Transporter99's Avatar
My Ride: Audi A5 3.2/6MT
I have owned 2 E30's. Most recently my beloved 1988 325is that is now sold. I bought a lot of my parts (clutch kits, brakes, etc) from Pelican Parts. I've never had an issue with them, and they performed well! I think 3K is a bit high and urge you to shop around. Check on George's (MITE46) E30/S54 build-up. You'll find many E30 guys hanging out there observing from other message boards, and offering technical support.
328i ZSP/ ZPP/ ZCW - Sold
_________________________________
'99 DINAN 328i - Sold
'93 Honda Civic Si - Sold
'09 Audi A5 3.2 6MT
'87 Ford/Merkur Sierra XR4 Turbo
Transporter99 is offline   Reply With Quote
Old 07-18-2006, 01:19 AM   #6
Devonjordan
My Ride: e46 325i
I have seen that thread, and definitely follow it closely.
Some of the stuff i know i can do myself, like the rear brakes. Also ive got a friend with a lift, so i can probably do the clutch with his help.
I knew that those prices were stealership status.
thanks for the help guys,
Devon
PS- anyone in socal who i can meet up with and talk e30, lets do it.
Old 07-18-2006, 01:44 AM   #7
rubberdub
My Ride: E46, E36, E30, E320
Honestly... Get yourself an M52 from an E36 ($700ish for an 80,000-mile motor used) and a 5-speed tranny ($300-600 used), and put that into the E30. You'll end up with a much better car, for about half the $3,000 you were quoted. E30 318 cabrios are dreadfully slow and lifeless, I'm sorry.
rubberdub is offline   Reply With Quote
Old 07-18-2006, 01:50 AM   #8
Devonjordan
My Ride: e46 325i
I was going to do that in the future anyways, just didnt know it was so inexpensive.
Old 07-18-2006, 08:27 AM   #9
e30cabrio
My Ride: 90 325ic
The quoted prices are sky high and the work is not that hard if you have basic skill.
Go to r3vlimited and e30tech. more e30 info than you can handle.
e30cabrio is offline   Reply With Quote
Old 07-18-2006, 12:00 PM   #10
rubberdub
M50 for $500: http://cgi.ebay.com/ebaymotors/1991-...QQcmdZViewItem
M70 V12 $1500 http://cgi.ebay.com/ebaymotors/1990-...QQcmdZViewItem
Old 07-19-2006, 08:31 AM   #11
King Luis
My Ride: 2004 BMW M3
If the body and suspension is in good condition, swap in a motor and all the current motor problems should be fixed.
King Luis is offline   Reply With Quote
