Old 08-31-2006, 09:59 AM   #1
vert
My Ride: MINI Cooper Hatch
Send a message via AIM to vert
RTAB replacement - special tool and some questions
Does anyone have a special tool for RTAB replacement and if yes - can I rent/borrow it from you? I was looking around and found the Victory tool but it's around 100 bucks which seems like a waste for a one-time (hopefully) job.
In addition, is 50K miles too low to worry about replacing the trailing arm bushings? I just replaced front control arms/bushings/tie rods/sway links and was going to get an alignment done. But then i was thinking that i might want to replace RTABs as well since this requires an alignment too. Bushings are cheap and DIY does not look that bad if you have the tool.
And finally, anybody knows where i can buy Meyle heavy duty RTABs?
vert is offline   Reply With Quote
