Other BMW Models
All other BMW model questions! For additional model specific forums check out bimmerfest.com! Please post all E90/E91/E92/E93 and new M3 news at E90Fanatics.com |
#21 |
thats pretty sick!
#22 |
where is bella motorsports in west palm?
Tom
04 M3 |
#23 |
Ernie Bello....hes in west palm yeah
330xi VF Charged Widebody
#24 |
Old Oakachobee and Austrailian Ave.
#25 |
i think the rims where 17's
#26 |
hmmm mayb they were 18's i forget
#27 |
Banned
The 335's are really nice. It's one of the cars I'm considering for my daily driver.
#28 |
Big in Japan
That thing needs a more aggressive diff like a hole in the head. It just needs an LSD!
#29 |
TWC Alumni
The stock rims flowed better. The BBS looks too small and narrow. E92 needs a fat 5spoke wheel.
#30 |
sweet, ill have to stop by...maybe they'd be good with installing headers and cams... btw 335i is sooo damn hot.
Tom
04 M3 |
#31 |
#32 |
sweet
#33 |
Very impressive.
#34 |
#35 | |
![]() Boost pressure is built in exhaust gases and engine load. Has NOTHING to do with final drive. If anything would be from lower final drive to get more load. But Boosted car can benefit from a longer first gear to take advantage of the turbo quick spool up and not waste it on tire spin and rev limiter coming so fast.
Rick
#36 | |
My Ride: Z3 3.0i, E39 3.0i
#37 |
TheOnlyConstantIsChange
Thats not how this turbo system works. Its not a sequential set up. Equal sized turbos are attached to 3 cylinders each and provide their own boost to each side. BMW preferred to use smaller turbos with quicker spool on each "bank" to ensure low end torque. Regardless of how the turbos are set up final drive still means nothing in the power category.
"Every man gotta right to decide his own destiny." - Bob Marley
'93 Toyota LandCruiser |
#38 | |
However, gearing does influence the drivability of a turbo engine car. Just as an example, off line in 1st gear, the car with the higher multiplying gear ratio is going to reach a lower RPM than the same car with a lower multiplying gear ratio at the same speed. Hence, as an example, at say 40mph, one car will be at 3000 RPM vs the other car will be at 4500 RPM. If your boost doesn't kick in until 4000RPM, then having the gear ratio that gets you in that RPM range quicker will make getting into the "boosted zone" easier. Typically, the car that gets into the boost zone quicker will be faster. At higher speeds, this becomes less significant as you can choose to use a lower gear to keep your revs up, and hence in boost. At lower speeds, you only have a few choices in gears and you can't go lower than 1st. In any case, if this engine uses smaller turbos that kick in at lower RPM ranges, then a lot of this matter less. |
#39 |
top end goes to the m3, idont know what your talking about
#40 | |
Oh indeed gearing changes drive ability but not actual power output of the engine. We reach agreement on that. As you said at the end BMW has elimated both of the cons of FI engines by going with this setup. Gearing can be kept the same as their NA engines because torque is available throughout the range and boost lag is non existant as well.
