Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 12-04-2006, 06:21 PM   #21
win-by-miles
It really was a Rocky story
My Ride: Refer to sig
Originally Posted by white46 View Post
couldn't you refund it?
i dont have recipt. but ill try after christmas
win-by-miles is offline   Reply With Quote
Old 12-07-2006, 11:47 AM   #22
thamindzzeye
My Ride: 2003 330ci
Smile You Rock white46!!
Hey thanks so much for this thread! I worked on it all of last sunday and I got my car all setup!!
I feel like an idiot for not realizing my car had this capability earlier. All those long months i spend listening to my single CD player now seem foolish!
In case anyone's wondering what I did was i ran 5 cables from my HU.
- 3 wires like white46 said to run the aux audio input
- 2 wires that carry power for my audio player
I found the plug that carried 12v when the car is turned on, and 0v when its turned off , and tapped into that as well as the ground cable. I needed a 5v for my ARCHOS AV700 player, so I used a total of 1.2MOhms of resistance to drop the voltage sufficiently.
Then I ran all the wires left through all my wood trim pieces, and over the dashboard to the middle of my dash where I am going to mount my player.
I can try to get some pics this weekend of what I have in mind, but I got all the wiring down, I just need to work on a custom housing for this honking player now.
Thanks to white, I have a great little project to work on this weekend!!!!
P.S. this forum rocks
thamindzzeye is offline   Reply With Quote
Old 12-07-2006, 10:40 PM   #23
white46
My Ride: e46 323ci
Great. You have taken it further.
I will be glad to hear everything workd out in the end.
white46 is offline   Reply With Quote
Old 12-07-2006, 10:45 PM   #24
clinique
clinique's Avatar
My Ride: 06 M3 Vert
nice work!
clinique is offline   Reply With Quote
Old 12-08-2006, 06:25 PM   #25
Critical_GP
My Ride: '00 BMW 323i SP
So, if my car is 2000 I cant do this? I cant unless I have the MODE button. I was going to ask about this but never had the time. Anyway, I went to Circuit City and asked if they had anything like that. The guy came back holding a box with a couple of wires in it and said its $80...he said that I connect my Ipod the same way as the changer. I was too iritated by the price and stoped listening! $80 for a wire....???
A friend of mine instaled his In-dash DVD and they charged him $20 for a piece of wire that costs $2.99 at Radio Shack. I know caz i bought that same wire to use it to connect my I pod to the HT system.
Now I'm gonna go check if my car has the MODE button....
Thanks...
Critical_GP is offline   Reply With Quote
Old 12-09-2006, 01:48 PM   #26
Gobanna
My Ride: E46-318i SE
Originally Posted by Ivegotissues666 View Post
No it wouldn't you would need a 09/03 build for aux in to work. Some 09/02 builds have the mode button but aux in still will not work for those models, only the BMW Ipod adaptor kit.
Jared
Would this work with euro spec 99 cassette HU's with the mode button? I have not checked the back of the unit to see if it has “external in R + L”
Gobanna is offline   Reply With Quote
Old 12-11-2006, 02:38 PM   #27
swervin22
My Ride: 325i finally modded
Send a message via AIM to swervin22
Did you have a chance to take any pictures of this?
swervin22 is offline   Reply With Quote
Old 12-11-2006, 03:01 PM   #28
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
Jared
You're one year off, the radio needs to be 09/02 or a SW of 43 or higher.
tom @ eas is offline   Reply With Quote
Old 12-11-2006, 03:01 PM   #29
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
This will not work on MY99 radios.
Old 12-11-2006, 08:47 PM   #30
silvscorp
My Ride: 03 CB M3 Coupe
my car is 03 and radio has a "mode" button. As I cycle the mode through, I see FM, CD and Trk. I don't see anything that says AUX. Does this mean I can't do this on my car?
silvscorp is offline   Reply With Quote
Old 12-11-2006, 09:04 PM   #31
boynamedsue
My Ride: 1995 325is
nice write up! do you have a picture with the HU back in? just curious to see what it looks like. good job again!
boynamedsue is offline   Reply With Quote
Old 12-11-2006, 11:38 PM   #32
white46
My Ride: e46 323ci
aux mode will only appear when something is connected to the input.
Old 12-12-2006, 07:41 AM   #33
silvscorp
You pointed out in one of the earlier posts saying this might not work for some early 03s? Can I just assume that it will work for any headunit that has a "mode" button or I'll have to try it out and see?
Old 12-12-2006, 09:12 AM   #34
white46
My Ride: e46 323ci
i'm not 100% sure if your hu has ability for aux input but I'm positive it does.
here is quote from Tom. Looks like any HU built date later than 09/02 or software 43 or higher can do aux input.
Old 12-12-2006, 12:50 PM   #35
win-by-miles
how do you check software version?
Old 12-12-2006, 01:41 PM   #36
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Here's how:
1. Turn Radio Off.
2. Turn Radio On.
3. Press and hold the "m" button for about 10 seconds.
4. Press < or > to navigate, you will need to go to the 2nd screen to look for the SW Verison which is in a SV xx-xx xx format.
5. To be Sirius/AUX or XM compatible, the radio must be SW 43 or higher.
6. Turn radio off to exit.
The MODE button is not a good enough of an indicator to check if a radio is AUX or Sirius compatible. It needs to be manufactured 09/02 or later.
Old 12-15-2006, 01:53 PM   #37
mircle
My Ride: '02 330i
where can I find the plug for the rear of the head unit?
mircle is offline   Reply With Quote
Old 12-15-2006, 03:08 PM   #38
silvscorp
I was trying to wire it up using a headphone plug and noticed there are only 2 wires coming out from a regular stereo cable. (L + R signal) How do I get the ground wire to connect? What kind of cable did you use? (you have 3 wires coming out from it)
Old 12-15-2006, 04:00 PM   #39
lethan7
My Ride: 330 ci 01
Unhappy
so now for us that have a 2001 that does not have with the mode botton .... what can we do to get aux in put ??
lethan7 is offline   Reply With Quote
Old 12-15-2006, 04:05 PM   #40
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
We have an interface that will convert the CD Changer input to an AUX port, this is plugged into the trunk.
We haven't placed the devices on the site yet, but I do have them in stock. Feel free to contact me interested.
bmw aux in, diy aux input, input cable
