Sponsored by The Tire Rack
Old 12-29-2006, 04:15 PM   #1
Addy25
My Ride: TitanSilber m3 Vert.
Send a message via AIM to Addy25
Are these tires healthy? Please read and comment
Hi All,
I just got a set of these 19" tires+wheels. Wanted to know if I should keep or return them.
Here are some specs.
235/35/19 All 4 Pilot Sport PS2's
One has a small bubble but the seller said the tire with the bubble has passed inspections etc and has not increased in size since last summer.
Rest have had some rubbing on the outside. The inner sides of the tires look very new. The outter rubbing is more obvious in the pictures with the bubble.
Please feel free to comment and give advice. I need to make a decision by tomorrow.
ID:	208461   Click image for larger version
ID:	208462   Click image for larger version
ID:	208463   Click image for larger version
Addy25 is offline   Reply With Quote
Old 12-29-2006, 09:41 PM   #2
Addy25
any suggestions, comments guys?? I would really appreciate it
Old 12-29-2006, 10:07 PM   #3
Cinna
My Ride: M3C
Send a message via AIM to Cinna
despite the rubbing and the single buggle, they appear as though they will run, have you tried driving with them yet?
Cinna is offline   Reply With Quote
Old 12-29-2006, 11:09 PM   #4
Addy25
Nopes, Not yet. but i've googled and looked on here and even called Gary today from tire rack, and the consensus is that any sized bubble is absolutely bad . Basically means sidewall has been breached. Hence my concern. I was also thinking that the rubbing should not be that big of a deal but I dont have much experience with Wheels and tires and hence I posted here
Old 12-29-2006, 11:37 PM   #5
deafboy
My Ride: 2000 323Ci
Personally...I wouldnt run em...but its up to you.
-Cole aka bigtall*****
Originally Posted by Owtlaw333 View Post
You'll always be pretty in my eyes, Cole :luv:
Originally Posted by Chrissspyy View Post
i was like passed out while she's shoving the entire bar in my mouth. :rofl: :rofl:
deafboy is offline   Reply With Quote
Old 12-30-2006, 12:02 AM   #6
ATC_Damian
My Ride: 2000 323i Touring
That bubble in the sidewall is an impact break and should be replaced. It happens when you run in a pothole, rut, or something and pinch the tire between the wheel and the pothole.
If you ride on it, it is going to get worse, but you definitely shouldn't ride on it at all.
ATC_Damian is offline   Reply With Quote
Old 12-30-2006, 01:35 AM   #7
Addy25
Thanks for the comments..Again much appreciated.
So the effects of rubbing should not be a problem correct?
The bubbled tire will def have to go..But i think the rest of the 3 should be good..
Do you folks agree?
Old 12-30-2006, 02:21 AM   #8
deafboy
My Ride: 2000 323Ci
yes...
that will work.
they wont last you too long though....
Old 12-30-2006, 07:46 PM   #9
Jeuprx-8
My Ride: rolls only Michelins
are these the 19"x8 front ZCP wheels that were for sale in the wheels forum?
Anyway... the bubble is from a hard impact and it means there is a cut in the sidewall and it is basically a small air pocket that causes the "bubble" It isn't really good or safe to drive on that tire, especially if you drive aggressive. The other tires don't look like they will last too much longer, you have to keep in mind that these are a 220 treadwear tire.
2006 Corvette Z06 Red/black
2006 BMW M5 Sepang/Sepang SMG III
2006 BMW M6 White/Black 6-speed
Jeuprx-8 is offline   Reply With Quote
Old 12-31-2006, 03:00 PM   #10
M3islove
My Ride: 2001 330Ci
Don't run them. I had similar bubbling. Long story short, the belt in the sidewall had come apart and was one step away from ripping apart completely. I watched the guy at the tire shop try to remove the tire and it ripped apart in his hand.
I'll take the wheels off your hands for the right price(w/o tires).
Image and video hosting by TinyPic
click above to be redirected
M3islove is offline   Reply With Quote
