Thread Tools Search this Thread Rating: Thread Rating: 474 votes, 4.95 average. Display Modes
Old 01-18-2007, 09:11 AM   #61
markz330
My Ride: 330 Ci M sport
Nice info...
thanx!
markz330 is offline   Reply With Quote
Old 01-19-2007, 04:03 PM   #62
steven107
My Ride: 2004 m3 coupe
nice write up, but wouldn't it be easier to buy an m3 instead of fully mod an 330? sounds like a lot of time, labor, and cost. for about 20k more, you can save time and get the bmw factory fit and finish without drilling or cutting and get the S54.
steven107 is offline   Reply With Quote
Old 01-19-2007, 04:14 PM   #63
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Most people get these parts secondhand and at low cost from friends who have replaced them on their M3... others just prefer the look of the M3 over all of the aftermarket alternatives. I made this thread to essentially save on labor costs - so people know what to expect when doing these conversions.
hi its me alec is offline   Reply With Quote
Old 01-24-2007, 01:50 PM   #64
so simple
My Ride: non bmw
i have a 328ci, so if i get oem m3 front fenders and bumper, itll fit on perfectly? or do i also need hood?
so simple is offline   Reply With Quote
Old 01-24-2007, 05:09 PM   #65
hi its me alec
You'll probably need to tweak the fenders a little bit inward, but yeah basically. There will be no welding or cutting or anything required in order to fit them, probably just about 10mins of tweaking (per side) to get the fenders and hood to line up perfect.. everything is bolt on (assuming you have all the proper m3 bumper bracketry and stuff).
It might look kinda strange though without the m3 hood.
Old 01-30-2007, 07:16 AM   #66
happybrowndog
My Ride: 330 CiC
Are you sure you don't need the hood? I called the dealer and they said you need the hood.... however, the parts person was getting this info by looking at the computer only and this information was not being conveyed by a mechanic who had done an actual conversion.
Do you have some direct or indirect experience with this? That M3 hood is very expensive.
2001 BMW 330Ci conv.
happybrowndog is offline   Reply With Quote
Old 01-30-2007, 08:15 AM   #67
hi its me alec
You do not need the hood.
Old 01-31-2007, 05:35 PM   #68
semantik
My Ride: 2001 BMW 330ci
Why not just save up and buy an M3, who wants their 330 to look like an m3, then pull up next to an m3 and get smoked... i never undertood this
semantik is offline   Reply With Quote
Old 01-31-2007, 07:47 PM   #69
hi its me alec
because most people get parts secondhand off of their friends for dirt cheap... others can't afford the insurance for an M3 (like me). there are plenty of reasons why people do this, i'm sure only about 1% of the people who have M3 parts on their car have them to look like an M3. for example, IMO the M3 side skirts and mirrors are lightyears ahead of their aftermarket alternatives.
Old 02-02-2007, 05:40 PM   #70
AMv8(1day)
My Ride: 280Z & POS Integra
Just a quick check, is there a difference between the 330ci coupes and the 325's between '01-'03 and how big of a tire can you get on the fronts and backs?
Thanks for any help anyone can give me!
AMv8(1day) is offline   Reply With Quote
Old 02-03-2007, 11:42 AM   #71
E46-99
My Ride: 99V 323Ci E46
love this thread, but m3 prices are dropping so im gonna keep saving,
99' E46 323ci -ci meaning costs infinate!
E46-99 is offline   Reply With Quote
Old 02-04-2007, 12:02 AM   #72
hi its me alec
There are no significant differences besides the engine (duh.) The biggest tires you can get on the car without major fender modifications is probably 245f 255r, but it really all depends on the width and offset of the wheel. With the right offset, fender modification, and a good set of tires, you can fit 275's in the rear. If you're dropped, the camber increases slightly and it might even be possible to go 285/30/19 in the rear (although nobody has done it yet.)
Honestly though, there are way too many factors that go into it... it depends 100% on your car, wheels, drop, fender mods, brand of tires, and more. For example, on my car with my 19's, I rub every so often with 235's in the rear.
Old 02-04-2007, 01:45 PM   #73
Tyler@UniqueDesign
Car Junky
My Ride: has a torn subframe
Send a message via AIM to Tyler@UniqueDesign
Brakes are smaller too.
And are you rubbing on the inside edge or the outside (fender) edge of the tire. If you are rubbing the fender then its wheel offset, if the chasis, you might try a 3 mm spacer. 235's should absolutely not rub.
Tyler@UniqueDesign is offline   Reply With Quote
Old 02-04-2007, 02:03 PM   #74
hi its me alec
I'm rubbing on the outside... it's only when I'm turning super hard at 30mph on a bumpy road or something. It's not really an issue, it's only happened about 5 times in the past year.
Old 02-12-2007, 04:06 PM   #75
rohde88
rohde88's Avatar
My Ride: S2000
Side Skirts:
Difficulty: 2/10
DIY: Yes.
Direct bolt on. No modifications needed. On sedans and tourings, the skirts will be a couple millimeters too long. No biggie though...
Safe Alternatives:
- Hammann GTR
- Hammann Competition
- OEM Mtech2
- AC-Schnitzer
- OEM Aero Kit (a.k.a. 'Mtech1')
Nice thread, I just wanted to chime in. Isn't also longer on coupes?
I've read that you can slide them back by elongating the mounting holes in the skirt.
Ron
-Ron
rohde88 is offline   Reply With Quote
Old 02-12-2007, 05:01 PM   #76
hi its me alec
Ron
no, coupe/M3 and sedan side skirts are different by about 1cm... M3 and coupe have the same side skirt length.
Old 02-12-2007, 05:27 PM   #77
rohde88
rohde88's Avatar
My Ride: S2000
Ok, but you can extend the mounting holes and have a flush mounting right(for sedan)?
Ron
-Ron
Old 02-12-2007, 05:35 PM   #78
hi its me alec
Ron
right
or you could just chop 1cm off one of the ends.
Old 02-12-2007, 05:49 PM   #79
rohde88
rohde88's Avatar
My Ride: S2000
right
this looks bad
i was under the impression that the only way fix this was to elongate the mounting holes. Also, I believe this isssue is on a coupe.
http://home.earthlink.net/~djburrows...330ci/id1.html
Ron
-Ron
Old 02-15-2007, 05:57 PM   #80
omegaoracle
BMW Sauber F1 Team
omegaoracle's Avatar
My Ride: 323ci
Informative, will be useful for years to come, and good reference for diy.
well done
omegaoracle is offline   Reply With Quote
