Old 12-01-2006, 02:02 PM   #1
3onDubs
3onDubs's Avatar
My Ride: no
Tail light warning fuse???
Does anyone know which fuse to pull to get the lights out warning for the tail and headlights to disappear? I have an 04 sedan......both headlights and both tail light lights-out warnings are appearing on my dash.
3onDubs is offline   Reply With Quote
Old 02-28-2007, 12:32 PM   #2
3onDubs
3onDubs's Avatar
My Ride: no
Thanks for the loads of support guys....
...does anyone know if pulling fuse 32 will take care of both sets (headlight and tails) or just the headlight warning?
Old 02-28-2007, 01:24 PM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Fuse 32 is only related to the headlight out warning system, it will not prevent the tail light out warning./
Old 02-28-2007, 01:54 PM   #4
3onDubs
3onDubs's Avatar
My Ride: no
^^^ Thanks...
Do you know if there is any way other than using resistors to get that warning to go away?
The reason I can't really use resistors is because I have aftermarket tails with a different connector...I would need to add a resistor for each bulb in the tail light.
