Old 03-13-2007, 02:31 PM   #1
Philbert
My Ride: 02M3|80 280ZX|87Yota
Vanlentine 1 Remote Display Inside the Gauge Cluster DIY (with pics this time!)
OK this is my second try posting this. There were some major issues with the hosting site for the photos, so I uploaded them to e46fanatics.com this time around, to ensure they would work. Sorry for the double post mods, feel free to delete the earlier one if you need to.
My goals:
1) Locate the remote display to a location where I could easily see it while driving, and not have to take my eyes off the road.
2) Relocate the remote behind the clear plastic gauge cluster (originally I was going to locate it behind the gauges and have the arrows show through with a cutout, but...that wasn't going to happen).
3) Keep it looking as clean/OEM as possible
Parts needed:
  • 1 E46
  • Valentine One
  • Valentine One Remote display kit
  • Small set of screwdrivers
  • Dremel kit
  • Torx kit (don't remember which sizes)
  • Double sided thin tape (scotch tape style and thinness)
  • 1 square inch of Velcro
  • 1 square inch of flat black material (I used a scrap from a photo album)
  • Glue gun and glue
  • Utility knife
  • 1 friend who knows how to solder very small things
And:
Being OK with not having the door open/signal light faulty display immediately to the left of the odometer.
Time:
For me....about 4 hours - but I know there are more skilled folks out there who will take less time.
Step 1: Remove the gauge cluster
Great DIY guide HERE: http://forum.e46fanatics.com/showthr...ighlight=gauge
Step 2: Take apart your V1 remote display.
There are two small screws in the bottom. Take these out and remove the PCB with the phone jack, as well as the front panel with the arrows. Everything else from the module is unneeded. Separate the PCB from the front panel - should just snap on/off.
Step 3: Soldering (the hard part)
I got a friend to help me with this who is an ace at soldering small things. Basically, you're going to need to first de-solder the phone jack on the PCB (and ensure that the 6 leads are NOT touching. Once the jack is off of the PCB, cut the long phone cord you've been using at the head - the part that plugs into the jack on the PCB (be sure to make a note of the order the 4 wires inside the phone line are so that they line up with the jack and the head).
Using a utility knife, cut back the sleeve of the phone cord to reveal the 4 wires within the phone cord. Using a small stripping tool. Strip off about 1/8 inch of each of the 4 wires to reveal their leads. Now, remembering the order of the wires, slowly and carefully solder the leads of the 4 wires (only the middle 4 are used on the PCB). Use a voltmeter/multimeter to measure resistance between the 6 leads on the PCB - there should be none, as none should be touching one another.
I chose to align the wires (and phone cord) in the opposite direction as they had plugged into the jack, so that they would now come out of the right side of the unit.
Once the solder is complete and the resistance confirmed null, drop a fat drop of glue on the wires/leads. Let it dry, and when dry, shave it as flat as you can with a utility knife.
Step 4: Dremeling the remote display front panel
The panel is nice, but it needs to be very flush and trim to fit between the gauge faces and the gauge cluster clear plastic. Using a dremel, neatly cut back the flange edges of the front display so that it sits flush when laid up against the PCB. It must be allowed to remain as thick as the area where the arrows are (and white plastic insert around the arrows). It should be no thicker than this.
Step 5: Mute button replacement
The mute button must come out for this mod - it's just too narrow an area. The button just pulls out - it's rubber. I used a piece of black photo album plastic and cut it small enough to fit behind the open space where the mute button was. Using double sided tape, I covered the hole from the back of the front panel. I then placed the black Velcro square behind that piece (this will later affix to the PCB when we install the whole unit).
Step 6: Get used to how everything fits...
The PCB is JUST narrow enough to fit inside the gauge cluster, through the hole where the door open/faulty bulb indicator is, just to the left of the odometer. Using just the PCB (now connected to the telephone wire), gently work the PCB into this area to get an idea of how it slides in. Find a comfortable spot where it sits just to the left of the odometer.
Step 7: The Install!
You've got all the parts prepped - now it's time to assemble. Place the dremeled front panel (with Velcro where the mute button used to be) into the gauge cluster, in the exact position you want it to be (just to the left of the odometer). Once seated nicely, get your PCB unit in hand and get ready to gently thread it through the opening you practiced in step 6. With GREAT CARE AND PATIENCE, insert the PCB from behind, aligning the Velcro/mute button side first with the front display. Once you have alignment with the front display on the mute button side (the side closest to the fuel gauge on your cluster), gently push the arrows side of your PCB into the hole. This is where it gets tricky...after you have the PCB entirely through the hole and aligned with the front panel, you'll want to GENTLY slide to toward the odometer hole with your thumb. This will, with just the right amount of pressure, gently secure the unit in between the clear plastic and the gauge panel (the remote display's front panel and the PCB are sandwiched against one another and the clear plastic and gauge face - it's like a shim.
Step 8: One more cut with the Dremel
If you now try to put the cluster back together (after cleaning up any and all plastic flakes from previous cutting), you'll notice it may not fit snugly. You need to cut one more hole. Using the dremel, cut a small hole at the bottom of the gauge cluster, giving just enough room for the phone cord to snake through. Once the hole is cut, snake the cord through and reassemble the cluster.
Step 9: Test
Test everything at this point - plug in your cluster and your phone cord and make sure it works.
Step 10: Reinstall!
Once it all works, thread the phone cord through the dashboard, through the footwell, into the center console near the shifter, and up into the glove box (if that's where you're tapping in for your hardwire). Put the cluster back, and you're in business!
NOTE: The photos show the phone cord coming out of the dash from behind the cluster this was for the testing purposes only once you know it works, you feed the phone cord through the dash opening where the cluster sits, and snake it down through the center console.
Hope this helps some of you out there - it's wordy but I tried to take a lot of photos to help. I love the new location of the display - I don't miss the part of the dash it's covering up too much either - I figure I know when one of my two doors is open, and if a blinker is out, I'll hear the double-blink.
Happy modding!
02 M3 Vert | 87 4Runner | 80 280ZX
Dinan S. | Clears | DiCE | OEM Alarm Retrofit | ACS Rep. Peds | DDEs
My Valentine 1 Hardwire | Remote Display Gauge Cluster Mod
Considering selling 2002 M3 Convertible (~38,000 miles) this year (don't drive it enough...). If seriously interested, PM me. SF Bay area.
Philbert is offline   Reply With Quote
Old 03-13-2007, 04:14 PM   #2
daytonaviolet
My Ride: 2004 M3
Send a message via AIM to daytonaviolet Send a message via MSN to daytonaviolet Send a message via Yahoo to daytonaviolet
excellent stuff philip that so clean... !
daytonaviolet is offline   Reply With Quote
Old 03-13-2007, 05:19 PM   #3
Philbert
Thanks Fern!
Was going to try to mount it *behind* the actual gauge faces (and cut out parts for the arrows and LED) but there wasn't enough room and I'm not that good at cutting stuff.
This puts it right where I can see it, and it's clean, like you said :-)
Now if anyone every finds a great way to stealth mount the actual detector in a vert (and preserve the forward and backward detection), let me know....
Old 03-13-2007, 05:24 PM   #4
clinique
clinique's Avatar
My Ride: 06 M3 Vert
thats clean
and i assume u didnt have to cut the gauge cluster?
just the remote display?
clinique is offline   Reply With Quote
Old 03-13-2007, 11:33 PM   #5
Philbert
Originally Posted by clinique View Post
thats clean
I did have to cut the gauge cluster - but only on the bottom, where you'll never ever see it...
Old 03-13-2007, 11:37 PM   #6
mark///m3
My Ride: turbo e30; x5 4.6is
awesome i love the no show installs. could almost pass for stock
___________________
Mark
mark///m3 is offline   Reply With Quote
Old 03-13-2007, 11:41 PM   #7
Philbert
Thanks!
Now if I could just hide that V1 main unit somewhere
Old 03-14-2007, 06:29 AM   #8
markusmark
My Ride: 2001330Ci
Mount it on the rear package shelf and hide it by installing the alarm sensor cover over it. See item #12 in http://www.realoem.com/bmw/showparts...36&hg=51&fg=55. I think someone on this site has done this and did not lose any sensitivy.
markusmark is offline   Reply With Quote
Old 03-14-2007, 11:56 AM   #9
Philbert
Hard to do on a CONVERTIBLE ;-)
Old 03-15-2007, 10:54 AM   #10
markusmark
My Ride: 2001330Ci
Ooops! Me bad!
Old 03-15-2007, 10:59 AM   #11
LAFENGAS
www.thielstudios.com
LAFENGAS's Avatar
My Ride: 330ci
Send a message via AIM to LAFENGAS
rear headrest?
LAFENGAS is offline   Reply With Quote
Old 03-15-2007, 12:16 PM   #12
Philbert
Originally Posted by LAFENGAS View Post
rear headrest?
Wow - that's cool!
But I think I'll keep it where it is - I do have passengers some times, and it's not that stealth, since I usually ride with the top down.
But very cool mod - nice work!
Old 03-15-2007, 03:43 PM   #13
JCz04Bimmer
JCz04Bimmer's Avatar
My Ride: 2004 330Ci & 06 Z4MC
Send a message via AIM to JCz04Bimmer
Looks excellent and I will probably do this myself at some point. I, however, plan to put display to the RIGHT of the mileage display. I have a manual car and there is a spot that is equivalent in size to where you put your device that is completely unused in manual cars. Usually it is where the gear number or R or D shows up on automatic cars. I plan to yank out that plastic piece there now, cut it up to be able to display the unit and then reinstall it.
Again, excellent write up and i intend to use it for my purposes.
JCz04Bimmer is offline   Reply With Quote
Old 03-16-2007, 11:27 AM   #14
Philbert
Sounds great - feel free to PM me if you have questions.
Regarding the cutting - you may not need to - I didn't. The front of the remote display (part that you see with the arrows, etc.) site in between your gauges and the clear plastic. The Actual PCB that has the LEDs and wires also sites between the front of the remote display and the gauges - so you likely won't have to cut any of your gauges/gauge covers to do this. And that will help when you sell the car ;-)
GL!
Old 10-05-2007, 08:08 AM   #15
fmzip
My Ride: '08 328xi / '01 530i
great job on the remote install....looks like I got a new project this winter! You can also wire a few leads from the PCB to a momentary switch to retain the mute function, then mount the momentary switch under the the steering column. This is what I did in my 530 when I molded the remote display into an area around my headunit.
If you want to make it smaller, you can cut the bezel and the PCB like I did. There are only two traces on that PCB that feed the mute button. Follow the traces on the PCB and solder the wires for the momentary switch to each point, Voila....you still have a mute function.
fmzip is offline   Reply With Quote
Old 10-12-2007, 02:13 AM   #16
jeffm3
My Ride: e46 m3
wow!!!!!!!!!!!!!! u r so cooooooooooooooool.................. bro!!!!
jeffm3 is offline   Reply With Quote
Old 10-13-2007, 10:07 PM   #17
BM-MAN
My Ride: Hot 3 coupe
Send a message via MSN to BM-MAN
Sweet mod. Nice and clean.....
BM-MAN is offline   Reply With Quote
Old 10-15-2007, 11:39 AM   #18
Philbert
that's hawt
Old 10-15-2007, 07:02 PM   #19
fmzip
thanks......
Old 02-12-2008, 02:18 PM   #20
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Pimp!!!!!
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
