Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
Rating:
Display Modes |
#1 |
BMW brake rotor facts and deductions
Here's the real answers to what seem to be the FAQ's. The facts are taken direct from the TIS, the deductions come from my engineering background. As always, please do not hesitate to identify and correct any errors I may have made.
Rotor sizes (in mm)323 - 286x22 front, 276x19 rear 325/328 - 300x22 front, 294x19 rear 330 - 325x25 front, 320x22 rear Minimum Acceptable Thickness for reuse - 323/325/328 - 20.4mm front, 17.4mm rear 330 - 23.4mm front, 20.4mm rear (deduced) Maximum Allowable Runout Disc on it's own - 0.04mm Disc installed - 0.2mm Is it allowed to machine (turn) BMW rotors? Yes, there is an actual BMW procedure in the TIS describing how to machine the rotors. You can machine them down to the minimum thickness if you need to. You do however, need to ensure that both sides are evenly machined and the appropiate runout and surface finish specifications are maintained. Should you machine your BMW rotors? Generally speaking, BMW rotors are cheap enough where it does not make economic sense to turn them. Plus, replacing them guarantees you will have a rotor with the correct runout and surface finish criteria. When do you have to replace your rotors? When they are below the specified minimum thickness. What if my rotors are at, but not below the minimum thickness? Then you can use them again, but only for one more set of pads, assuming you are using OEM pads or pads with equal or less rotor wear than the OEM pads. What's the theory behind the minimum thickness criteria? When BMW selected the pads and designed the rotor thickness, it was not done randomly. The expected range of rotor and pad wear is known and designed on purpose. Your pads have a wear sensor which goes off when you have 3mm or less pad material. It is a safe assumption that the pad wear sensor is designed to go off before you wear your rotors down so thin that they are hazardous. So the deduction from this is that the wear rate of rotors with OEM pads is 1.6mm or less per set of pads. Which in turn means the absolute safety limit of rotor thickness is probably about 18.8mm front and 15.8mm rear (for 323/325/328 - add 3mm for 330). To put it another way, the BMW rotors and pads are designed in such a way that if you reuse the rotors at minimum thickness, your pad wear sensor will go off before your rotors get too thin. So do should I replace the rotors everytime I replace the pads? Assuming they are at or above the minimum thickness for reuse and are otherwise within spec, it's up to you to strike the best balance of tradeoffs between performance and money. It is an absolute certainty that you will get better braking performance out of new rotors than reused rotors. But depending upon the condition of the rotors, the difference in performance may be slight. The one thing you do NOT want to do however, is reuse rotors with a non-OEM brake pad of unknown wear rate. By doing so, you run a very serious risk of having a higher rotor wear rate than was intended by design. As a result, your rotors may become dangerously thin and even fail before the pad wear sensor goes off.
#2 |
Regional Sponsor
My Ride: 2000 E46 with 254K
You forgot to have on there DO NOT TURN M rotors!
Seth Thorson Service Manager/BMW Tech JB Eurotech Service "Your Reasonable Dealer Alternative" General Questions can be sent to appointment@jbeurotech.com 1. Do not argue with an idiot. He will drag you down to his level and beat you with experience. 2. Light travels faster than sound. This is why some people appear bright until you hear them speak. |
#3 |
Didn't forget it, didn't know it.
Are you specifically refering to the ones with the floating disc design? I can see where that wouldn't work out very well.
#4 |
Regional Sponsor
Look up M3 rotors it says right in TIS do not machine M rotors, weird huh I never rec machine any BMW rotors, I used two and have changed my mind after years of real world results with turning BMW rotors. Do a search on a thread where me and Alex323i had this discussion
#5 |
nice job jpr! great info as usual. i like how you included "BMW", "brake", and "rotor" in the title, shouldnt be missed on the search.
![]() 3 SERIES OWNERS MANUAL IN PDF Tech, DIYs, Forums The Most Explicit Content on E46Fanatics!! my obligatory DropBox and SugarSync links. |
#6 |
Wierd -I'm running a somewhat elderly version (Dec 2000) of the TIS, which only covers the E46 M3 up to 2001, largely prior to it's USA debut. There is no such disclaimer on my version.
But back checking to the E36 M3, it is exactly there where you said it would be - "(M models may not be machined)" So the two questions are - (1) did the non-machining direction get included for the E46 M3 in a later version of the TIS? (2) Why not? As noted above, my first guess would be that the real issue is the compound floating rotor design prevents accurate machining, but are there other considerations? And for that matter, did the E36 even use that design? As I recall the thread you're refering to, I believe the conclusion was, yes you can machine the rotors, but it's to imagine the circumstances where it would be worth the bother (and expense).
#7 |
my TIS version 3.4.1 (NOV-2003) states the front or rear M3 rotors not be turned.
![]() 3 SERIES OWNERS MANUAL IN PDF Tech, DIYs, Forums The Most Explicit Content on E46Fanatics!! my obligatory DropBox and SugarSync links. Last edited by flyinj3x; 03-24-2007 at 07:32 PM. Reason: fix |
#8 |
Thanks for settling question 1.
Any ideas on question 2?
#9 |
Hey.. I thought this would be the right thread to ask since its about brakes/rotors. The auto places around here have nothing listed in inventory for brake pads OR rotors for a 2000 328CI (my car) but they DO HAVE brakes/rotors for the 325CI -- will these brake/rotors fit my car? When I search around for "e46 brakes" I see most brands fit ALL (323/325/328/330) but NOT M-series, so I assume the brake pads/rotors will fit from a smaller-engined 3 coupe?
Thanks for any help. |
#10 |
Rotors - the 323 and 330 have uniquely sized rotors, the rotors on the 325 and the 328 are the same.
Pads - the 323, 325, and 328 all use the same calipers and therefore all use the same pads. The 330 has different calipers and use different size pads. The M3, is of course, it's own animal all the way around.
#11 |
Thanks for your response. So, any E46 328/325 rotors I could use (I guess that means .. 99 - 2005), and any E46 323/325/328 brake pads will work?
Thanks in advance!! |
#12 |
correct
#13 |
Network Analyst
Minimum disc thickness is stamped on the disc. No need to deduce anything.
Because the B isn't for bling.
#14 |
Yes- that would be the fact part, not the deduction part. It's also in the TIS and handy thing to know without having to look at your disc, say for example when your shop is on the phone trying to sell you new discs because at they are almost at the minimum thickness.
#15 |
Network Analyst
Then why is deduced in paranteecees ( I can't spell that damn word)?
#16 |
I listed the 330 rotor minimum thickness as deduced since, my version of the TIS predates the introduction of the 330 and does not have that info. The deduction is that they use the same designed rotor wear rate. IF you can confirm it, that would be helpful.
#17 |
Just like the E46 M3, US versions pf the E36 M3 got 1-piece rotors and Euro got the floating design.
- Rob
#18 | |
What do you make then of the proscription on machining the "M" rotors? Is the terms "M rotor" BMW code for floating rotor, or is there something special about even the 1 piece rotors that prevents them from being able to be machined?
#19 |
Just to consolidate info, here's the E46 M3 rotor sizes -
M3 - 325x28 front, 328x20 rear M3 optional drilled (ZCP) - 345x28 front, 328x20rear I believe the minimum thickness would then be 26.4mm and 18.4mm, but it would be nice if someone could confirm this.
#20 | ||
I suspect that the TIS uses "M rotor" to mean floating, but cannot substantiate that beyond a qualified guess. - Rob |
