Old 05-04-2007, 02:32 PM   #1
wceoscar
My Ride: 323i
HID Question
Ok, so i finally decided to install a HID kit on my low beams, since i don't turn on my high beams too often...
The kit that I'm buying is a Siemens H7 HID kit http://lchid.en.alibaba.com/product/...rsion_Kit.html
Will this fit like Oem, without letting water-dust into the headlamp???
What Kelvin would look better in my titansilber 323i??
Will i get the headlamp failure message on my dash??
wceoscar is offline   Reply With Quote
Old 05-04-2007, 03:28 PM   #2
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
i assume u have halogens.. same with me. im not sure about that kit but i made sure there was no open flow going through the headlights with some silicone.
u will probably get the bulb out warning on your dash until you actually turn the lights on.. then it goes off
BreakMyWallet is offline   Reply With Quote
Old 05-04-2007, 04:16 PM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
When you purchase an H7 HID kit, you will need to modify the base of the bulb and housing in order to make it fit as they are not direct replacements.
Old 05-04-2007, 06:48 PM   #4
wceoscar
My Ride: 323i
Ok, So what about if i get a Oen Kit **** this http://i3.photobucket.com/albums/y61...5IZlwPq_ph.jpg, will the light still be on?
Also, is there a way to prevent the dash light comming on?
I would like to see a few configuraton with different colors!
Also what temp i s this on the fogs http://www.bmtown.com/imagedata/all/HID-Xenon-10L.jpg
Old 05-04-2007, 08:50 PM   #5
sillieidiot
My Ride: '06 AW 330ci
yea the warning light will still come on. you have to flash your car to make it go away or pull fuse 32.
why don't you just buy p46's? it's pretty much plug and play. jlevi can help you out with that if you have anymore questions.
and for the fogs, they look like 8000k.
Old 05-04-2007, 10:41 PM   #6
wceoscar
My Ride: 323i
great, so by pulling fuse 32 the light would go away??
Old 05-05-2007, 12:15 AM   #7
sillieidiot
what year is your car? for 99-00 cars that's possible.
