Old 02-16-2007, 01:27 PM   #1
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
DIY Stop using carb clean for vaccum leaks!! Here is a alternative
Build this smoke machine for under $30 and be able to find vaccum leaks the correct way!! Carb clean will not show most vaccum leaks, this will help you find those very small vaccum leaks!! This inert smoke will fill the intake and leak out the smallest leaks, indicating where you have an issue. This is the only way to properly find a vaccum leak!! Our profesional machines work better. However most of you DIY's do not have the money to drop on the tools that we use. But this will get you close!!
Name:	smoke machine.jpg
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 02-16-2007, 01:50 PM   #2
Alex323Ci
My Ride: M3 & 323Ci (sold)
Seth, are you saying this going into the intake and leaks outs(not that you fill the engine compartment and look for it to go in right?) Also what's with the diesel glow plug?
OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK
CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF
Old 02-16-2007, 01:58 PM   #3
jbeurotech
Regional Sponsor
Yup goes into an intake use or intake inlet. Glow plug must be powered up to burn the fluid causing the smoke.
Seth Thorson
Old 02-16-2007, 08:50 PM   #4
---zxcvbnm---
My Ride: 1999 328i
Most people who drive bmws have no clue what a vaccume leak is let alone what to do with this tool. Its sad but true. Thanks for the info
---zxcvbnm--- is offline   Reply With Quote
Old 02-16-2007, 10:35 PM   #5
Rotha
My Ride: N/A
okay so attach 12 volt source to glow plug. lol i get it now.
I think i might be the type to go to spencers and get a smoke machine for 30 dollars.
thank you so much though. This is pretty smart
The best thread on e46fanatics. Prompt answers by knowledgeable people and you don't get flamed for it.
http://forum.e46fanatics.com/showthread.php?t=523290
Welcome to e46fanatics.
Rotha is offline   Reply With Quote
Old 02-17-2007, 01:43 AM   #6
jbeurotech
Regional Sponsor
the smoke machine spensors uses will not put enough pressure out and do this job as needed. also not sure what they use for smoke, I know thi is safe to put into your car!!
Seth Thorson
Old 02-17-2007, 01:44 AM   #7
jbeurotech
Regional Sponsor
I would tend to agree but I get auffly tired of hearing spray it with carb cleaner to find the leak!! So I made this post to inform peopl of the right way and proper way wiether they use it or not I can stop answering questions on how to find small leaks
Seth Thorson
Old 02-18-2007, 10:28 AM   #8
supark
My Ride: E60 M5, 69 02
huh - nifty! Definitely sounds like a useful tool - done my share of trying to find vac leaks with carb cleaner, always a pain.
supark is offline   Reply With Quote
Old 02-19-2007, 11:59 AM   #9
Tom Busby
My Ride: 2001 325i, 1995 318i
Brilliant tool idea! Thanks for the picture and post.
Tom Busby is offline   Reply With Quote
Old 02-20-2007, 09:39 AM   #10
PreppyR6
My Ride: shines like justice
Hey, you got any pics of an actual diy machine like this? Im trying to get ideas of how to what kinds of parts and how to connect.
Das Weena!
PreppyR6 is offline   Reply With Quote
Old 05-08-2007, 10:19 PM   #11
GRIDLOCK
My Ride: E36 / E46
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
Old 05-09-2007, 12:32 AM   #12
mikepbrooks
My Ride: e46 323i
Send a message via AIM to mikepbrooks
i really hope someone didnt copy this guys idea and made those...
You have big shoes on your car ehh? Well i wear size 13 shoes, so what do you think is big on me? Thats right my socks...and what of it!
I like long walks on the beach at sunset and picking flowers to smell them...I hope no one reads this...
Find me on MySpace and be my friend!
mikepbrooks is offline   Reply With Quote
Old 05-09-2007, 03:46 AM   #13
asilva
My Ride: 05' X3 3.0
how about the propane method?
Fail, Fail again, Fail Better"
asilva is offline   Reply With Quote
Old 05-09-2007, 12:57 PM   #14
Lemonsqr
My Ride: 2001 TiAg 330i
what do you mean? The OP didnt come up with the concept of a smoking vacuum leak detector. What he drew out was just a schematic of the basic things you need to make one yourself. Every commercial smoking vacuum detector is based around the same basic parts...a low pressurized air source to force the smoke into the engine, some way to regulate it, a way to generate engine component/sensor safe smoke and the plumbing to hook it all together and to the engine...
Lemonsqr is offline   Reply With Quote
Old 05-09-2007, 06:40 PM   #15
mikepbrooks
My Ride: e46 323i
oh ok my bad....
Old 05-09-2007, 07:40 PM   #16
GRIDLOCK
My Ride: E36 / E46
Went to the local Lowes and they didn't have squat as far as metal containers go (steel or aluminum)...
Any recommendations on where to go? I am definitely going to build one and put up a DIY!
Old 05-09-2007, 11:25 PM   #17
mikepbrooks
My Ride: e46 323i
probably could use something food or something comes it...check wally world lol
Old 05-09-2007, 11:34 PM   #18
Lemonsqr
Dood! get creative If I were going to do this, I would try to find a hand held pesticide or weedkiller sprayer with a metal can, put a glowplug through the bottom with a nice gasket or petroleum proof sealant and replumb the pickup tube in the metal resevoir so you are only sucking out the smoke you are generating. This way you dont have to worry about electric pumps and extra plumbing. Just make sure the sprayer you get has a high enough pressure to force the smoke through the whole engine. I would imagine 10psi is more than enough. Good luck
Old 05-09-2007, 11:44 PM   #19
bmwstephen
My Ride: e46 325xi, e30 325is
Send a message via AIM to bmwstephen
what is the method DEALERSHIPS use to find vaccuum leaks?
seth you should start making a couple of these and selling them here
bmwstephen is offline   Reply With Quote
Old 05-10-2007, 02:19 PM   #20
Lemonsqr
They use commercially available smoke machines.
