Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc. |
#21 | |
Brackets are $150 each, rotors are like $235 (332mm) to $340 (355mm) each depending upon size. You already have pads and lines that will fit ST-40 calipers?
03 coupe, TiAg, 6MT, TCK DA w/ plates/RSM/RCA, GC sway, MagnaFlow, KN 63, UUC SSK, pullies, Shark, Recaro, Schroth, StopTech BBK, SSR GT1, RD strut bars, Powerflex RTAB/FCAB, OEM LED tails, OMP pedals, VCSL CF roof, hood, trunk, diffuser, console, Odyssey, Kirk, Clutch Masters |
#22 |
Europrojektz Southeast
I have an extra set of pads from my front BBK. I have a set on ss brake lines for the rear and for stock calipers. I am guessing they won't fit right. Also, I saw a while back that you were looking to trade a set of red color calipers for black. Do you still have the red set as my front BBK is red?
#23 | |
I ended up installing the red calipers as my front kit. The calipers have center inlet for the brake lines.......the lines supplied with my kit when I bought it had a banjo type connector not screw in like OEM.
#24 |
pic of front kit presently installed on my car.
#25 |
finally sold
