Thread Tools Search this Thread Rating: Thread Rating: 263 votes, 5.00 average. Display Modes
Old 07-08-2007, 01:31 PM   #1
Deep Blue
Banned
My Ride: M52TUB28
solution: Check engine light w/ aftermarket Headers
Headers and/or Cats: Catalytic Inefficiency solved
WHO: People who upgraded to aftermarket headers without installing any catalytic converter will get a catalytic inefficiency error code. Likewise, people who install high-flow catalytic converter will get the same "inefficiency" error codes.
WHAT: Catalytic Inefficiency codes on the post cat 0xygen sensor: P0420 (cylinder 1-3) P0422 (cylinder 4-6).
Ref: http://www.obd-codes.com/trouble_cod...old-bank-1.php
WHY: The reason why your OBD-II diagnostic systems report this error code is because the 02 sensors detect an above normal exhaust reading when compare to OEM catalytic converter. The OEM catalytic converter does an excellent job at filtering/cleaning/converting exhaust fumes into cleaner air. The DME/ECU calibrates its post-cat sensors to the OEM catalytic converter performance and specs. Therefore, aftermarket cats do not clean well enough to satisfy the catalytic efficiency monitoring of the DME. This is a very common problem with aftermarket cats especially the high-flow ones.
An "inefficiency" reading does not mean that your catalytic converter is broken especially if it is brand new. Again, the error codes just means that they are not performing as efficient enough to meet OEM standards.
SOLUTION: There are three feasible options to solve this inefficiency problem
  1. Ignore.
  2. Spark Plug non-fouler (aka Spark Plug defouler)
  3. Software upgrade
-Ignore-Since the post catalytic converter oxygen sensors is purely for emission monitoring it does not in ANY way affect your fuel trim and car performance. Therefore, it is perfectly fine to ignore the check engine light.
-PRO: No time and resources wasted on fixing problem
-CON: Annoying check engine light
-Software Upgrade-Software upgrade from major tuning companies will flash your DME to remove the "catalytic efficiency" monitoring feature.
-PRO: Fast and requires no hardware/equipment modification to exhaust systems
-CON: Expensive
-Spark Plug non-fouler (aka Spark Plug defouler)-By installing the spark plug non-fouler, you are in essence moving the rear 02 sensor out of the direct flow of the exhaust stream/flow. By doing so, you are tricking the 02 sensor will an inaccurate reading. Since the 02 sensors is not directly in the path of the exhaust fumes, it can not accurate measure the exhaust fumes.
-PRO- Inexpensive
-CON- None
HOW:
People aftermarket headers w/o cats
Go to Autozone and buy a pair of 18mm long and short "Spark Plug Non-Fouler."
Brand: HELP!
Part Number: 42009 (short) and 42002 (long)
Price: $3.50 for 42009 and $3.50 for 42002
Modify the short spark plug non-fouler (P/N 42009) to make the hole bigger in order for the oxygen's sensor tip to fit comfortable inside the spark plug non-fouler
Install your 02 sensors as followed:
O2 sensor, modified short fouler, long short fouler.
You are using two non-fouler to increase the distant between the exhaust fumes and the 02 sensors.
People with aftermarket headers and cats
Since you already have cats, you don't need to move the oxygen sensor out of the direct exhaust fumes as much as the people without cats.
Go to Autozone and buy a pair of 18mm long "Spark Plug Non-Fouler."
Brand: HELP!
Part Number: 42002 (long)
Prce: $3.50
NOTE: The package only comes with 2 non-fouler. In the picture above, there are 3non-fouler as reference only to help illustrate what a non-fouler looks like from different perspectives
O2 sensor, long short fouler.
NOTE: You might need to modify the long spark plug non-fouler (P/N 42002) if your 02 sensor's tip doesn't sit properly inside the spark plug non-fouler.
NOTES:
The oxygen sensor shown in picture is a pre-cat and NOT a post-cat. Only used as reference to help illustrate installing the non-fouler into the sensor.
When installing cats, you do not need to extend your o2 sensor. Simply re-wire the 02 sensor wire harness inside the engine comparment. This will give you an additional 3-4 feet of wire.
I hope this helps. Post your questions here if you have any. I am willing to help any fanatics with this modifications via online or in person for free.
Deep Blue is offline   Reply With Quote
Old 07-08-2007, 01:49 PM   #2
douglas_ngo
Europrojektz Southeast
My Ride: Hamann Widebody
Do you think this will work on my 2003 530I? It has Dinan CAI, software, header, and Supersprint cat back exhaust system. I am getting CEL for running without cat. Thanks
douglas_ngo is offline   Reply With Quote
Old 07-08-2007, 02:14 PM   #3
Deep Blue
Banned
My Ride: M52TUB28
This modification is non car/make specific. therefore, it will work for any car. the concept is the same. You are removing the post-cats o2 sensors out of the direct flow of the exhaust fumes/stream to trick oxygen sensor.
Old 07-08-2007, 03:31 PM   #4
frobie15
My Ride: has a door star
Send a message via AIM to frobie15
I'm getting the aftermarket cats and post cat O2's installed this week. If it still throws the CEL, I'll look into doing this. Great write up!
Go ahead, ask me a question... Check out the CopTalk thread in the California forum
Thank you Sam
frobie15 is offline   Reply With Quote
Old 07-08-2007, 08:09 PM   #5
Deep Blue
Banned
My Ride: M52TUB28
UPDATE:
I recently upgraded to headers. Because I am from California, installing Cats is a must due to the strict emission laws. However, even with the cats installed, I was getting the check engine light. After doing some research, I conducted the defouler trick.
After peforming this fix, my car has logged over 200 miles and my check engine light hasn't come back once. I scanned my car for hidden error codes with my Peake Reader and it seems like the "inefficiency" codes is a thing of the past.
I have a better picture of the modified/drilled out defouler if anyone wants to see it. The hardest part is drilling out the darn suckers. It is tuff and you get metal shaving/shapnels in your eyes, ears, balls, and mouth.
Good luck with this DIY. Again, your mileage may vary depending on your car's setup.
Old 07-10-2007, 03:21 AM   #6
frobie15
Originally Posted by Deep Blue View Post
UPDATE:
How?
But seriously, did you use a drill press? Or at least a vice?
Thank you Sam
Old 07-10-2007, 03:46 PM   #7
Spitfire
My Ride: 2001 330CI
Nice detailed and organized write up. This should help a lot of fanatics out.
Daily: E46 UUC SwayBarbarians, UUC RKII, UUC TSE3, OEM Clears, ICE->Link, ACS rep pedals, M3 style lip spoiler, balls of steel, H&R sport cupkit, UUC EVO3/DSSR, hyperblack 18" CSL reps
Track: E30 325 with S52; H&R Race/Billie Sports, IE sways, SSK
Spitfire is offline   Reply With Quote
Old 07-10-2007, 05:43 PM   #8
Deep Blue
Banned
My Ride: M52TUB28
Originally Posted by frobie15 View Post
How?
How? Because I was completely naked when I drilled the spark plug non fouler. Something about dremels and handy tools brings the wild manny side out of me
anyhow, all I used was a small drill bit and a sanding tip. The small drill bit is to drill the hole big enough for the sanding bit to fit over. This is not the best method. However, it was my only method since I didn't have any access to the huge azz drill bits and power tools.
Here are some updated pictures:
1) Before and after. What your modified non fouler should look like after you drill them
shameless plug for BMW F1 Motorsport
2) Noticed how the spark plugs sit snuggly into the spark plug defouler. Again, you drill the defouler so that the oxygen sensor plug's tip can fit inside. If not, there is no way for you to screw on the 02 sensor since the hole is just too small.
shameless plug for UUC motorwerks
3) different angles of the oxygen sensor tips installed in a modified non fouler.
Old 07-13-2007, 03:07 AM   #9
frobie15
Shameless plug for Trident?
Shameless plug for Hotpoint stove?
Thank you Sam
Old 07-15-2007, 09:48 PM   #10
Deep Blue
Banned
My Ride: M52TUB28
here is two pictures of the spark plug defouler being installed on my exhaust system
Old 07-15-2007, 10:13 PM   #11
KrisL
My Ride: 03 330i ZHP
Send a message via AIM to KrisL
Very nice write-up. I've added this to the Bimmerfest wiki.
http://www.bimmerfest.com/wiki/index.php/BMW_E46
KrisL is offline   Reply With Quote
Old 07-16-2007, 12:09 AM   #12
Tommyboy
My Ride: 335i
i got cats with my after market headers and no CEL, but the only thing is my cats freaking scrape over speedbumps. i wish they made 3" cats
Tommyboy is offline   Reply With Quote
Old 07-16-2007, 12:31 AM   #13
Deep Blue
Banned
My Ride: M52TUB28
cool thanks
Old 08-09-2007, 04:39 PM   #14
frobie15
I just installed the long non foulers on my car after drilling them out. By the way you need a 1/2" drill bit to drill it out large enough. It'll be wait and see if the light is thrown again. I'll keep people posted.
Thank you Sam
Old 08-09-2007, 08:35 PM   #15
Deep Blue
Banned
My Ride: M52TUB28
Cool. Please keep us posted. Show us some pictures of your drilling job also.
P.S. Are you stationed at fightertown, USA?
Old 08-10-2007, 12:39 PM   #16
frobie15
Not stationed there, but I live about two miles from it. I get to hear 'em flying overhead every so often.
My drilling job looks exactly the same as your grinding job.
Thank you Sam
Old 08-10-2007, 12:42 PM   #17
frobie15
I threw two codes on the way home from my girlfriends last night. Neither was for the catalytic efficiency below threshold. They were;
P1447 - Manufacturer Control Auxiliary emission Controls
P1190 - Manufacturer Control Fuel Air Metering
Any thoughts?
Thank you Sam
Old 08-12-2007, 12:29 PM   #18
Deep Blue
Banned
My Ride: M52TUB28
Any thoughts?
According to the Blentley P1190 is your Pre-Cat 02 sensor (bank1) going bad. Check the connector. Trying swapping the 02 sensors and see if the problem go away, stayed, or transferred with the swap.
p1447 is your emission control (ie Purge value or DM-TL Diagnostic Module Tank Leakage).
Old 08-12-2007, 05:39 PM   #19
botaman
My Ride: 330xi/530 Blown
This is awsome, very nice write up. I will do this to my 5'er soon
botaman is offline   Reply With Quote
Old 08-12-2007, 05:54 PM   #20
frobie15
Sweet, thank you! Looks like I'll be replacing my O2's (there originals with 113k miles on 'em). As far as the other two things. I guess I'll have to pull out my Bentley to do a little research and find out how to fix them, eh?
Thank you Sam
