Go Back   E46Fanatics > Everything Else > The Off-Topic > Health & Fitness
Health & Fitness
Discuss any topics related to heath and fitness here.
Old 08-01-2007, 01:33 AM   #1
ALPINEMSIX
My Ride: Msix
Send a message via AIM to ALPINEMSIX
neck(trapezius) excersizes?
So the only trapezius/neck excersize i know is the "shoulder shrugs" where u take the dumb-bells and while holding them with ur arms straight u pull up and then back down again.
any other excersizes i can do?
ALPINEMSIX is offline   Reply With Quote
Old 08-01-2007, 02:03 AM   #2
SurreyF1
My Ride: BMW
hello again
i do shoulder exercises for my shrugs, and i can feel that they work pretty good as an alternative to doing shrugs
ugh i'm horrible at explaining how to do this haha......
well i'll hold dumbbells on each side (20lbs for me) and raise them with my arms fully extended, not bent....
so you hold the weights where your hips are, and raise them to your sides, not to your front........ i lift them until my arms are level with my head, then back down
it works the shoulder primarily but i can def feel it in my traps the next day...
hope this helps to change things up a little.....
SurreyF1 is offline   Reply With Quote
Old 08-01-2007, 02:43 AM   #3
M3_POWER
My Ride: 2005 M3
Traps were a weak point with me, and I wanted to get them to grow quick. Since hitting them hard for about 3 months now, I've seen great gains. I hit them 2-3 times a week. I will usually do a couple heavy days with a lot of sets (10-15) with reps around (8-15). I will throw in a light day for my traps with higher reps and less sets (5-8 sets/ 12-15 reps). I will always mix up my exercises. I will switch back and forth from dumbbell/barbell/machine shrugs. I will do behind the back shrugs once a week as well. I also incorporated a new exercise that my friend showed me. I would use an incline bench and lie facing the bench. Traps should be treated like calves; you need to hit them frequently, hard, and with many heavy sets/reps due to their fast recovery..... Hope this helps!
M3_POWER is offline   Reply With Quote
Old 08-01-2007, 06:39 AM   #4
Dalton
I'm hot 'cause I'm fly
My Ride: goes wshh
Power Cleans work them pretty well.
Dalton is offline   Reply With Quote
Old 08-01-2007, 10:49 AM   #5
46_coupe
My Ride: is lame
Traps are probably my easiest stimulated muscle hands down. All I do are heavy shrugs and an array of cleans and they grew!
"As soon as you're born, you start dying, so you might as well have a good time" - Cake
46_coupe is offline   Reply With Quote
Old 08-01-2007, 11:06 AM   #6
User Name
My Ride: 330xi
Lateral raises, go as high as possible (i.e. past horizontal with the floor).
User Name is offline   Reply With Quote
Old 08-01-2007, 05:47 PM   #7
BeRzErKaS
BeRzErKaS's Avatar
My Ride: 330ciC; Boosted E36
Send a message via ICQ to BeRzErKaS
Try switching from dumb bell shrugs to barbell shrugs.
Palms up, palms down, close grip, wide grip, arms straight, arms bent, bar in front of you, bar behind your back..etc...etc...etc....
Deadlift day is a good day to hit the traps too since you already have the bar loaded up HEAVY.
BMW 3 Series - "Welcome to the club."
Supercharged E-dIrTy-6 325is 5sp
Drop Top E-sPorTy-6 330cic Step
BeRzErKaS is offline   Reply With Quote
Old 08-04-2007, 12:52 AM   #8
BrianJ1888
My Ride: 330i ZHP Imola Red
when I played football in HS, we had machines that were designed to work the neck muscles in 4 directions. it was basically a pad attached to a lever that you dropped plates on. you just pushed against it, raising the weights. 90lbs on that was standard. you could probably find this machine at a good gym.
BrianJ1888 is offline   Reply With Quote
Old 08-04-2007, 09:22 AM   #9
bimmerchop
My Ride: spins 4
Send a message via AIM to bimmerchop
http://www.exrx.net/Lists/ExList/BackWt.html
- Rich - Flickr - Stage 3+ TiAL B5 S4
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster." - Jeremy Clarkson
euro.techniks
EPL | TiAL | SDR | APR | Stratmosphere | 034 | ASP | SPEC | Fidanza | STaSIS | H-Sport | AWE | H&R | StopTech | BBS
bimmerchop is offline   Reply With Quote
