Old 10-28-2007, 11:19 PM   #1
hawkeyesfan
My Ride: 2002 a4
Send a message via AIM to hawkeyesfan
350z vs supercharged 325i
who would win? Also, how far would it be behind a cayman s?
hawkeyesfan is offline   Reply With Quote
Old 10-28-2007, 11:53 PM   #2
mcr_driver
My Ride: my favorite two feet
might want to be a little more specific about what type of supercharger and also at what PSI is it running. if its less then 6.5PSI it might not be able to keep up with either and would barely keep up with 350Z (assuming its the 6 speed not the auto's auto's lose almost 20 HP) and the cayman S (also a 6speed assumption) would leave both behind nicely. BUT if its a 8.5-9.5 PSI system it might be able to hang with the cayman S and beat the Z. just depends really.
mcr_driver is offline   Reply With Quote
Old 10-29-2007, 06:27 AM   #3
malina
My Ride: stock ZHP
Frankly speaking I never knew if 350Zs I raced were auto or 6MT, but they all lost to a 5MT e46 325i with 8PSI. I'm curious about capabilities of Cayman S myself
malina is offline   Reply With Quote
Old 10-29-2007, 12:58 PM   #4
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
the new dual intake (newest vq) 350z makes about 270 to the wheels automatic..
so... if the 325 is force inducted and makes around the same horse power mark via pulley or headers or whatever... it should start pulling away becasue of more torque.
the cayman is quicker but may not be faster.
"I hated cutting suckers with my razor blade. But everyday it's a struggle to get major paid. Anyway
it's so hard on a Jigga in this city, no pity..And ain't no love for the scrubs that be buying dimes.. If you could walk a mile in my shoes.."
MachRc is offline   Reply With Quote
Old 10-29-2007, 07:37 PM   #5
Tyler@UniqueDesign
Car Junky
My Ride: has a torn subframe
Send a message via AIM to Tyler@UniqueDesign
It would pull only if it weighed less. The area under the dyno on the VQ35HR is significantly fatter than previous VQ engines.
I've got a 13.2 at 105.69. Where are SC'd 325's running in the 1/4. Whats the gain they get in the second 1/8th. I'm picking up ~25 mph.
edit- Don't forget, the Z has at least a 3.538 rear gear in a 6-speed manual. So the 325 loses the gearing battle as well.
Tyler@UniqueDesign is offline   Reply With Quote
Old 10-30-2007, 09:33 AM   #6
MachRc
E46Fanatic
MachRc's Avatar
the thing is only 2 outta 15 or so 350z will be this new vq35hr(high rev) 270-289 whp machines.
the rest are going to be non-track based non-lsd 235-245 whp models.
but then again..
the chances of running into a 325 with a blower...that has about 270-280 whp
is gots to be like
2 outta 10,000
Old 10-30-2007, 09:54 AM   #7
malina
My Ride: stock ZHP
Are you talking about Nismo edition? Never met one on the streets.
Old 10-30-2007, 10:05 AM   #8
defex
My Ride: 330i
Nope. all new Z's are running low 13's in the 1/4 now. The older version(which I had) ran high 13's. They've received a dramatic increase in power.
defex is offline   Reply With Quote
Old 10-30-2007, 11:26 AM   #9
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Its amazing how much quicker the Z is compared to the G... I consistently walk Gs with bolt ons, but have mixed results with the Zs
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 10-30-2007, 02:39 PM   #10
malina
My Ride: stock ZHP
How come new Zs are still heavier than e46 325s? Base Z is 3,313 lb. vs e46 325 3241 lb.
Old 10-30-2007, 04:23 PM   #11
Tyler@UniqueDesign
Car Junky
I dunno - part of its a 20 gallon gas tank and those weights are with a full tank of gas.
The chassis wasn't designed for the Z specifically, but for the murano, the Z, and the G, so it had to be adaptable and that led to extra weight. Its definitely stiffer, but I dunno what causes the weight to be so high.
And most 07 owners will never get low 13's. I went to the strip a lot and am driving the crap out of the car. That 13.2 is currently the best of any stock Z, so take it as you will.
The Nismo will run slower, stiffer suspension and more aero drag both kill its launch/trap abilities. The powertrain is essentially identical, so no help there.
Old 10-30-2007, 05:44 PM   #12
malina
My Ride: stock ZHP
^ What track do you go to? I went to Moroso a couple times. Even though it was my first experiense at the drag strip and I know pretty little about drag racing, I can say that Moroso strip sux, as I get a much better traction on a regular highway.
Old 10-30-2007, 05:55 PM   #13
Tyler@UniqueDesign
Car Junky
Moroso doesn't have a bad track, part of it is not being used to the surface. Sometimes prep is better than other times, that was probably the key thing.
Line up in the rubber of a car with slicks. It helps a lot. VHT is great, but rubber and VHT is soooo much better.
I'm running Gainesville mostly. I'll make a trip to Bradenton someday, I've heard its a better track but runs slower so you get less attempts in.
Old 10-30-2007, 08:15 PM   #14
Tazlord
My Ride: 2003 330i ZHP
And here I was, hoping for a cool video ...
Tazlord is offline   Reply With Quote
Old 10-31-2007, 12:37 AM   #15
david05111
My Ride: drei hundert dreißig
So wait...the new Z is quicker than an e46 m3?? Holy crap!
"You'll Never Walk Alone"
"Psycho Murican" -- beeemerdude of Canada
Follow me on Instagram: yippee_ki_dave
david05111 is offline   Reply With Quote
Old 10-31-2007, 05:28 PM   #16
Activ3
Well like Tyler said, he holds the record for the fastest recorded 1/4 time @ 13.2
If you want to compare, the fastest recorded time for a stock M3 I believe is 12.7.
Old 10-31-2007, 08:38 PM   #17
GodSendsDeath
My Ride: 2008 350z 6-speed!!!
There is no use, they don't know much about the HR down here in E46 crowed. A 07-08 would pull on a E46 SC 325 what are they 260whp yeah, thats what a Z dynos stock except his gearing is better.
http://i75.photobucket.com/albums/i288/Edvin328/cutie.jpg
GodSendsDeath is offline   Reply With Quote
Old 11-01-2007, 12:33 AM   #18
Tyler@UniqueDesign
Car Junky
Already talking smack now are we.
I've yet to find a stock M3 to race, I really want to see a stock/lightly modded M3 at the track so I can compare 1/8th and 1/4 speeds (since the driving is unlikely to be equal) given same conditions. I'd bet its closer than any M3 owners would want to admit.
Old 11-01-2007, 12:54 AM   #19
Activ3
I just ran my friends m3 from 2nd gear @ 40mph... I was dead even up till the end of third, and he began to pull from there. He's lightly modded with headers and software.
Tyler, I believe most M3s trap ~107 in stock form.
Old 11-01-2007, 05:44 AM   #20
Tyler@UniqueDesign
Car Junky
Some do, most seem to trap 105/106 - and race gas seems to really help. The results so far have been no change in trap speed on race gas for the Z guys, but I haven't tried it yet myself.
I trapped that in 68, frankly I expect a better trap when it gets in the 50's. Everyone posts runs from ~50 degree weather and I'm getting close with a 20 degree handicap. Thats another .2 off my time if I drive right...
