#1 |
front brakes torque spec question?
Hello everyone,
I am doing front brakes/rotors on 03 325xi and need to know the torque specs for caliper bolts and slide pins. Thanks for replying. |
#2 |
sorry I have no personal experience with this and therefore do not know the torque specs that you need. However, maybe you will have better luck in the DIY/tuning section? Look under one of the stickies (the threads that are locked on the site by moderators for their information/ease of use)
VF570 S/C|TIAL BOV|SetRabCooler|Brembo GT 6/4|TE37s|NT05s|3.91 Gearing|TCK D/A|RPi Induction|SS Race Mufflers/X-pipe|JVT Headers|AS SSK|Sparco Pro2000/6pt.Harness|MS FloorMounts|SE Custom Harness Bar|Tekarbon Angels|M-Tech Pedals|OE Strut Bar|RE RSMs|8000K D2S|CDV DEL|CF Roof Wrap|MB Grills|UUC TrannyMounts/ClutchStop|V1 Mount|P3C Gauge ![]() |
#3 |
Owner/Admin
http://forum.e46fanatics.com/showthr...t=brake+torque
I'm sure if you search around you can find the guide pin specs. I want to say it is 54 ft/lbs but that is a guess, I never use a tq wrench on those. Tim
#4 |
From the Good Book:
caliper to brake pad carrier mounting bolts: 22 ft-lbs. brake rotor to hub mounting screw: 12 ft-lbs. pad carrier to front steering arm: 81 ft-lbs. (what a pain!) and, for completeness: pad carrier to rear trailing arm: 48 ft-lbs. (rear brakes only!) -J |
