Old 01-17-2007, 03:53 AM   #1
jpupster
jpupster's Avatar
My Ride: e46 323ci, e21 320is
Rear tail light problem
The rear tail lights on the left side are dim, the rear tail lights on the right side are bright. I checked the bulbs on the left and they are fine, but are dim (weak). I did notice the black plastic connector (wiring) that connects to the light bulb housing (holder) is burnt and one of the spade pins is burnt. Any DIY links for a fix? Likely, other BMW cars have had this same problem. Is this a ground wire problem? Need help and assistance. Car inspection time is coming. Thanks .
jpupster 323ci
jpupster is offline   Reply With Quote
Old 05-31-2007, 05:52 PM   #2
numba1guju
My Ride: 2013 328i
Send a message via AIM to numba1guju
wow man, you got no help with this, i had the same problem, my entire light just went out
2002 325i: Black/Black
Mods: Clears, VM V715 Matte Black 19in staggered, 20% tint all around, Suspension Technique Coilovers, p46s 6000k w/ aurora 60LED
numba1guju is offline   Reply With Quote
Old 06-01-2007, 01:00 AM   #3
az-03-325xi
My Ride: 3 guesses...
http://forum.e46fanatics.com/showthread.php?t=472357
plus more if you search
az-03-325xi is offline   Reply With Quote
Old 10-27-2007, 05:01 PM   #4
Sunny31
My Ride: e46
wow I have same problem, my left side is brighter than the right and the left side the ground wire is all burnt up and the connector is sort of broken, Could this be why that side is brighter than the other? Im positive its not the bulbs cause I switched them all around.
Im also getting some annoying bulb out warning on my right side for some reason AGHHHHH
Sunny31 is offline   Reply With Quote
Old 10-28-2007, 03:30 AM   #5
dayclone
My Ride: 01' 320i
Hey guys!! Perfect for you I just fixed mine.!!
Driver side was toasted for me pin 5 was gone totally black and burnt out and melted my light bulb holder, and the connector.
Did you guys want me to write up a DIY??
I'm guessing yes I call it... Tailight Connector/ Holder Fix.
It's a very common problem in E46's.
EDIT:
Refer to my guide guys. Hope it helps.
http://forum.e46fanatics.com/showthread.php?t=516775
dayclone is offline   Reply With Quote
Old 10-28-2007, 12:48 PM   #6
naser
My Ride: 03 325i
I had exactly the same problem, including the connector toasting. I suspect it started because the connector pins don't fit very tightly and with time they develop a high resistance. I twisted them all so that they press hard into the socket, and that fixed it.
naser is offline   Reply With Quote
Old 10-28-2007, 08:51 PM   #7
Sunny31
My Ride: e46
I fixed my problem by just taking the ground wire and connecting it to the metal piece on the bulb housing. The other side where I was getting the "light out error" and it being dimmer than the otherside was fixed by simply replacing the back part (the bulb housing part) with an spare one I had lying around from my stock amber lights and it did the trick. No more light out error and the brightness is identical to the other side
Old 10-29-2007, 11:12 AM   #8
pvandyke
My Ride: 2002 325i
I did the same thing as Sunny31. Worked great.
pvandyke is offline   Reply With Quote
Old 10-29-2007, 09:20 PM   #9
cliff101
My Ride: 02 330xi w/sport pkg
I had the exact same problem on my right side.....i checked and it was the ground wire that was loose in the connector so what i did was twist the whole light wire up while the lights were on and when i saw the lights get brighter i kept it in that position and tighten the light housing back in....everything has been fine ever since the warning went off also
cliff101 is offline   Reply With Quote
Old 12-04-2007, 02:52 AM   #10
F0iL
My Ride: AW 03' 325i
I have the same problem with my left side being dimmer than my right side. I also have the problem with having a error on the passenger side. It comes on every now and then I guess Ill check out my ground wire on the left side.
Sunny31 - Can you explain to me how exactly you fixed the error code for the rear light. What do you mean by the back aprt of the housing? The part where you screw it in? Do I basically need to just replace the bulb so I dont get the error anymore? Thanks
F0iL is offline   Reply With Quote
Old 12-04-2007, 08:56 AM   #11
ssm1991
My Ride: 2004 325i
http://forum.e46fanatics.com/showthread.php?t=512469
ssm1991 is offline   Reply With Quote
