Old 12-14-2007, 05:13 PM   #1
butwhynott
My Ride: 03 330xi
03 330xi cab replacement. HELP!
Does anyone have any info on replacing the cabs in an xi?
butwhynott is offline   Reply With Quote
Old 12-14-2007, 07:42 PM   #2
az-03-325xi
My Ride: 3 guesses...
I did this and didn't think that the XI procedure differed greatly from a non XI. Any question you have in particular?
az-03-325xi is offline   Reply With Quote
Old 12-14-2007, 08:27 PM   #3
butwhynott
My Ride: 03 330xi
What stumped me is how you get to the 2 bolts that hold the CAB mounting brackets.
Old 12-14-2007, 08:32 PM   #4
az-03-325xi
i assume you are talking about the passenger side. it was a *****, i used a fixed wrench and probably spent 15min per bolt because of the clearance.
Old 12-14-2007, 08:53 PM   #5
DesertMotorWorks
Past Site Sponsor
My Ride: 2004 330CI
DesertMotorWorks is offline   Reply With Quote
Old 12-14-2007, 08:53 PM   #6
butwhynott
My Ride: 03 330xi
When I looked at the clearance, from the top of the bolt head, it looked like I only had about 1/2 an inch. You were able to unscrew the bolt enough to get the bracket off? Is the drivers side easier?
Thanks !
Old 12-14-2007, 09:11 PM   #7
az-03-325xi
i believe i loosened the heat shield so it opened up some room. the drivers side does not suffer from any clearance issues so its a breeze.
this pic shows everything removed.
Old 12-14-2007, 09:26 PM   #8
az-03-325xi
pretty interesting PDFs DesertMotorWorks.
I used a 3 jaw puller rented from autozone to separate the bushing from the CA, very easy
separatingthe bushing from the carrier is another story altogether, what a pain. the pic timestamps are correct in that i spent ~5 hrs just on the bushings & carriers.
putting the new bushing on CA was simple though. dish soap inside the bushing and just a quick motion to press it on. if you have any trouble with this I'd say use more soap
Old 12-14-2007, 09:56 PM   #9
butwhynott
My Ride: 03 330xi
Guys, youve been great. Im gonna give it a go in the morning. If you dont hear from me call the police because Ive taken a sledge-hammer to my car. lol. Wish me luck. Thanks for all the info.
