Old 03-27-2007, 12:44 AM   #1
Nilz-323i
My Ride: 323i-4dr Black
Halo Ring Outtage ...wierd
So i recently got P46's and Halo rings with them and after the install they all worked fine..nothing wrong at all...couple hours later when i went to turn on my car...one wasn't working..so i thought maybe the bulb just went..so i got a replacement bulb from bimmian under warranty and just installed it today since i haven't had time since then...put it in..worked not problem..again couple hours later went to turn on my car and the same thing..that same ring wasn't working...i checked the ballast connecting other connector ring which was still working to it and it lit up fine..no problems...so im gonna try replacing the bulb again...but if it goes out..does anyone know why it might be doing that?...would the ballast be messed up? Too much power coming from somewhere all of a sudden?..thx...any advice would be appreciated...
Nilz
Nilz-323i is offline   Reply With Quote
Old 03-27-2007, 01:01 AM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Have you tried just starting up the car? It could be that the ring is just cold and is not at full brightness.
Old 03-27-2007, 09:27 AM   #3
Nilz-323i
Yes i did..i thought it was that but the weather isn't cold anymore..thats why i did the replacement now...its like 15-20 degree's here in Toronto...it's just funny and wierd because that same bulb i changed went again...do you think it could have any thing to do with the ballast?
Nilz
Old 11-06-2007, 01:59 AM   #4
muskamatt
My Ride: 330ci
i have seriously the same story except after i got my replacement and everything worked fine, they all went out. Now i am down 250 and dont know what is wrong with my lights. I was thinking the same thing about the power but i honsetly just dont know. PM me if you find anything out man i would appreciate it
muskamatt is offline   Reply With Quote
Old 11-06-2007, 02:02 AM   #5
sillieidiot
My Ride: '06 AW 330ci
damn this is an old thread.
anyhow muska, did you check the fuse? if they all went out, that could be it. or you're not getting any power from the positive tap.
Old 01-10-2008, 05:29 PM   #6
Kris325xi
My Ride: 2001 325xi
I know this is an older thread... but better to post here than a new thread.
I'm having similar problem with a ring out... and i'm getting a replacement bulb for the ring...
I already checked the inverter... but when I get a replacement bulb for the ring where does it go? I'm not even sure where on the p46 the bulbs are at?
Does it come with a guide on where the bulb is at?
Kris
Photo Sharing and Video Hosting at Photobucket
Kris325xi is offline   Reply With Quote
Old 01-10-2008, 05:35 PM   #7
sillieidiot
you have to open the p46s, and open the plastic rings. that's where the ccfl tube goes.
Old 01-10-2008, 05:37 PM   #8
Kris325xi
My Ride: 2001 325xi
Ok, doesn't seem that bad then at all... Thanks!! : )
