Rating:
Display Modes |
#21 |
I'm going to be replacing the oil level sensor on my '02 coupe in not too long, along with an oil change. How tough is that reinforcement plate to remove? Looks like it has to come off to get at the sensor.
Also, my Bentley manual says that the bolts securing it should be replaced every time they're removed, because they're "use once" fasteners. Anybody know offhand what size and grade they are, so I can get replacements before starting the job? Thanks in advance. |
#22 |
I'm going to be replacing the oil level sensor on my '02 coupe in not too long, along with an oil change. How tough is the reinforcement plate to remove? Looks like it has to come off to get at the sensor.
Can one do this on ramps, or do you need jackstands for this? I prefer to use ramps for stuff where the wheels don't have to come off, but I note that the Bentley manual says not to drive the car without the reinforcement plate installed, so I'm a little worried about keeping weight on the wheels while removing the plate. Also, my Bentley manual says that the bolts securing it should be replaced every time they're removed, because they're "use once" fasteners. Anybody know offhand what size and grade they are, so I can get replacements before starting the job? Thanks in advance. |
#23 | |
as far as the fasteners, i don't think you have to change them, but here's the part numbers just in case HEX NUT BM6-8-ZNNIV SI quantity: 3 part # 07129905411 |
#24 | ||
Biggest problem was torquing the fasteners back down for that plate--was a *real* pain to turn the rear ones the required 90+30 degrees, even with a two-foot breaker bar. They're recessed, and in at an angle, so it's not easy to apply the amount of torque they require. Quote:
It's really kinda weird that the E90 has no dipstick and just uses the level sensor. I guess you end up overfilling it when the sensor burns out? Kinda reminds me of that apocryphal story about NASA and the USSR's space agency, whose name escapes me at the moment. NASA spent millions of dollars researching a pen that didn't rely on gravity for ink feed, so the astronauts could write in space in zero gravity. The Russians just issued their cosmonauts a pencil. Moral: don't overthink things. |
#25 | ||
that NASA thing is funny, i remember that story i couldn't do the no dipstick thing, i'm really not liking the way some newer car designs go, and it's not just bmw, mercedes is the same going away from the dipstick relying on a stupid sensor. |
#26 |
Hey guys, when doing this did u guys buy a new oilpan gasket too, or is the one on there fine to re-use?
What's the oil sensor part#, and gasket, if needed. Sorry I'm postong from my phone and it just would take forever to find it. |
#27 | |
www.realoem.com should have part numbers--not sure if they're different year-to-year. For a 2002 330Ci--my car--the part numbers are: Oil level sensor: 12617508003 (no indication that it comes with a new gasket) Gasket: 12611744292 Yours may be different. Also, ask the parts person whether the sensor you order comes with a new gasket--no sense in ordering an extra gasket you don't need. |
#28 |
Ok, cool.
Ill have a looksee when I get home in the morn. I know a guy that knows a guy. So I should be able to get it cheaper than normal. Also, I was thinking. Are these replacement sensors an upgraded better one, or will they be doing the same as the original one in a couple thousand miles or so? |
#29 |
Unless someone knows better, I would suspect they're identical to OEM.
It seems that one thing that often leads to failure is draining the oil with the key turned on. The sensor was not meant to be entirely dry. Draining the sump with the sensor powered up burns out the sensor. Reading the threads on this board, I do note that a suspicious number of these sensors fail soon after someone has an oil change performed somewhere. ![]() I really feel bad for E90 owners who don't have a dipstick as a backup. |
#30 |
Hahha, yeah, that's a scary though.
Ill be sure to remember that when changing oil in the future. Thanks. |
#31 | |
And the sensor will come with it own gasket. Right guys? I am going to do mine on my next oil change too. |
#32 | |
Past Site Sponsor
Oil Level Sensor comes with it's own gasket If anyone needs an Oil Level Sensor, I have them in stock! |
#33 |
What happens if you don't care about the yellow oil light and decide not to change the sensor? Will you mess up anything in the long run?
![]() "I'm gonna die! Jesus, Allah, Buddha - I love you all! -Homer Simpson |
#34 | |
Past Site Sponsor
#35 |
how much do u sell the sensor for duder?
#36 |
what does it do?
I don't have to use dipstick??
![]() NY->Salt Lake City within 48 hours |
#37 |
it keeps tabs on the oil level while your rolling down the road since u cant check the dipstick while moving.
there is also one for oil pressure too. |
#38 |
Past Site Sponsor
#39 |
so it's not something that shows oil level on the cluster?
#40 |
in a sense. Oil level is low, light comes on, lets you know to tap up so u dont damage anything.
