Old 02-09-2008, 12:23 AM   #1
whitearchangel
My Ride: 323i
Headlight problems after new battery installed
I had a new battery installed two days ago,and tonight after getting dinner, i started my 2000 323i and turned on the headlights. They came on and as I was backing out they flashed as if they turned off and on. As I was driving I noticed that they did that several times. At a stoplight The lamp indicator showed my left tail light was out, then it went off. Could it be that the battery cable is not on tight enough? I neve had this problem before.
whitearchangel is offline   Reply With Quote
Old 02-09-2008, 03:42 PM   #2
sillieidiot
My Ride: '06 AW 330ci
it sounds like a loose ground. definitely double check the battery connections.
