Old 02-09-2008, 10:08 PM   #1
freshprince2421
My Ride: 325ci
Unhappy Predator Chromium Disaster!!
So I installed my angel eyes about 2 years ago. Since then I've already replaced one ballast. Recently I noticed that my angel eyes will only turn on when my cabin lights are on; they are only getting power from my remote kit. And at some point my driver's side angel eyes stopped illuminating.
So to recap, when my cabin lights are on only my passenger side angel eyes light up. In all other situations neither side lights up. I've searched and it seems like I might need to replace my fuse? Where is this piece and how can I tell? I'm thinking I'll also need 1 ballast.
Any ideas ???
freshprince2421 is offline   Reply With Quote
Old 02-09-2008, 10:31 PM   #2
SK328CI
SK328CI's Avatar
My Ride: 2006 Jeep SRT8
yea, i had mine for 2 weeks and problems after problems. i just got fed up of the piece of **** and took out the fuse.
SK328CI is offline   Reply With Quote
Old 02-09-2008, 11:45 PM   #3
SammyV
My Ride: CB M3
Send a message via AIM to SammyV
i doubt its the fuse, that sounds like A. one ballast is blown out and B either the ecu trigger wire or the power wire there is a bad connection someplace..
SammyV is offline   Reply With Quote
Old 02-10-2008, 06:21 PM   #4
freshprince2421
My Ride: 325ci
Arrow
so they're still on they jsut don't work? lol
I'll check the connections. What should I look for when I examine them? Thanks.
Old 02-10-2008, 07:21 PM   #5
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Well let's back up here. I wouldn't really call this is a disaster
What most likely happened is a ballast shorted or part of your wiring shorted, blew the fuse and cut the ECU tap. The remote kit is fused separately by the stock interior lights fuse. Try replacing the fuse on the wiring harness to see if that solves the issue.
Old 02-11-2008, 02:36 AM   #6
freshprince2421
My Ride: 325ci
Ok so how can I verify that the fuse is blown? Where is it installed?
Thanks Nick.
P.S. You don't happen to have any extra ballasts/fuses here at school do you?
Old 02-11-2008, 12:05 PM   #7
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
The fuse is located on the wiring harness near the positive portion of the terminal.
The fuse holder is outlined in this picture below. Just flip open the holder, pull out the fuse and look at the metal Z in the middle. If the Z is broken, you need a new fuse (10 or 5amp works) which you can get from Radio Shack.
Old 02-11-2008, 03:04 PM   #8
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Forgot to mention I don't have extra parts with me on hand
Old 02-11-2008, 03:24 PM   #9
sillieidiot
My Ride: '06 AW 330ci
sounds like 1 ballast is out as well as the fuse blowing out.
Old 02-11-2008, 09:59 PM   #10
freshprince2421
My Ride: 325ci
Thanks for the clarification Nick.
Rats. Where can I pick up a ballast?
Old 02-11-2008, 10:22 PM   #11
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
I don't know of any places locally but we can send you one.
