Old 03-10-2008, 05:37 PM   #1
sdbimmer
My Ride: 2004 325Ci
O2 Bank 2 Sensor 1, which one?
Question for you guys: which O2 sensor is the Bank 2 Sensor 1? I know it's the Pre-Cat sensor, but which one is it. There are two, one closer to the firewall and one closer to the front of the car.
Can anyone tell me which O2 Sensor is Bank 2 Sensor 1?
Thanks a lot.
sdbimmer is offline   Reply With Quote
Old 03-10-2008, 06:11 PM   #2
smolck
My Ride: 2004 ZHP Sedan
Thanks a lot.
It's the one on top of your manifold. The easy one to get to. If you remove the plastic cover you'll see it.
Check out my BMW Blog
http://smolckbmw.blogspot.com/
Check my Youtube channel for DIY's and fun stuff
http://www.youtube.com/user/flipfinish?feature=mhee
smolck is offline   Reply With Quote
Old 03-10-2008, 06:17 PM   #3
sdbimmer
My Ride: 2004 325Ci
But isn't there like two of them on top? I think only one of my sensors is defective. Since it cost an arm and a leg to replace, i want to see if I can replace just the bad one, which it Bank 2 Sensor 1.
Old 03-10-2008, 06:18 PM   #4
1bad420a
My Ride: 02 325i
bank one is cylinders 1-3 bank 2 is cylinders 4-6 so its the rear manifold top sensor
1bad420a is offline   Reply With Quote
Old 03-10-2008, 06:31 PM   #5
sdbimmer
My Ride: 2004 325Ci
So looking at the diagram, it should be #2 sensor (one closes to the firewall)?
Thanks for the info.
Old 03-10-2008, 08:26 PM   #6
grafiksguy
My Ride: 2010 328xi
You don't say what your mileage is, but if you are at the point where you're replacing the O2 sensors, do yourself a favor and do them both at the same time. For the $70 or so for the second sensor you'll buy yourself another 100K.
grafiksguy is offline   Reply With Quote
Old 03-10-2008, 08:37 PM   #7
gokcer
My Ride: 323Ci Sports Package
Usually you change them in pairs. Unless one went out prematurely you should replace both precat ones.
Looking for a cheap Auto Insurance? Try AutoInsuranceGeek.com
If you have helpful tips about auto insurance, email me at info@townsbestsingles.com
Bright-Red 323ci 5sp. Sports + Premium + Homemade K&N intake box. --> DIY Instructions
Also for single fanatics try My 100% Free dating service - TownsBestSingles.com
New House Tool 4 in 1 Mortgage & Tax Savings Calculator for home buyers
gokcer is offline   Reply With Quote
Old 03-10-2008, 09:03 PM   #8
sdbimmer
My Ride: 2004 325Ci
It's an 2004 and has 86k miles. The cheapest I found that is a (Bosch) direct plug-in is from Autohausaz for $135.00. Part# 17216
http://www.autohausaz.com/search/pro...xygen%20Sensor
Old 03-10-2008, 09:41 PM   #9
guest1016
fanatical
My Ride: .
Send a message via AIM to guest1016
i had one go bad around mmmm maybe 25k miles, i can't remember, but the car was out of warranty so i bought a new one through the local bmw parts dept. and paid less than that.
guest1016 is offline   Reply With Quote
Old 03-11-2008, 03:43 AM   #10
sdbimmer
My Ride: 2004 325Ci
Yeah, I think the 2003-2006 models use the newer O2 Sensor. Which cost a lot more than the older ones.
http://www.realoem.com/bmw/showparts...55&hg=11&fg=50
Here is a pic of the older O2 Sensor:
older sensor plug:
and the newer O2 sensor looks like this, I guess:
Old 03-11-2008, 08:53 AM   #11
ddombrowski
My Ride: 01 330ci 5spd
Send a message via AIM to ddombrowski
The last time I replaced an O2 sensor was on my dad's eclipse, and I bought a bosch universal (you have to splice the wires) for $60 instead of the $100 for the one with the connector.
When I had to replace the second one (and I did have to replace the second one shortly after), I found that autzone had the bosch one with the connector for $75. Not sure if they've dropped in price or what, but I was pleasantly surprised to see that autozone had a really good price for something I could pick up right away.
ddombrowski is offline   Reply With Quote
Old 03-11-2008, 08:54 AM   #12
ddombrowski
Oh, and I don't know how much your time is worth, but Im not getting another universal O2 sensor if I can help it. The thing worked fine, but it took my about 30 minutes to crimp all the wires and seal them up. Not worth the small difference in price for me.
Old 03-11-2008, 01:06 PM   #13
security6
My Ride: 2001 330i
Yes. Bank 2 is the header closest to the firewall.
If you have to do bank 2, sensor 2, then it is the oxygen sensor that is more difficult to reach (sensor furthest from the center of the car).
security6 is offline   Reply With Quote
Old 03-12-2008, 12:31 AM   #14
sdbimmer
My Ride: 2004 325Ci
Just for future reference, here it is:
Old 06-11-2012, 02:55 PM   #15
combo9011
My Ride: 08BMW 528XI
Hello Sdbimmer !! Thank u fo the diagrams!! I have the same problem, now I can see clearly which one i need but most likely I might have to buy both . Is it true that both top 2 sensors are the same . One out of two dealers told me that the pre cat sensors are the same ..well to my 08/528xi ..? the other dealer told me differently so I took non of their advice !!
combo9011 is offline   Reply With Quote
Old 06-11-2012, 03:17 PM   #16
sdbimmer
My Ride: 2004 325Ci
combo9011, for your car...08/528xi it is different (length wise at least). This is what i got from RealOEM.
Old 06-11-2012, 03:26 PM   #17
combo9011
@sdbimmer ! Oh thank u so much !! I really apreciated ..! So the #2 is the one I need replace according to the chart ? The chart is actually similar to your previous charts
Old 06-11-2012, 03:38 PM   #18
sdbimmer
My Ride: 2004 325Ci
#2 is (Bank 2, Sensor 1) and for your car it is a little shorter than the sensor in the front. they are basically the same sensor. If the shop doesn't have #2, you can probably just buy #1 to put into #2 position. That's probably the reason why the shops are telling you both answers.
Old 06-11-2012, 03:46 PM   #19
combo9011
I'm happy !!! Good and fast advice sdbimmer!!!!
Old 06-11-2012, 03:54 PM   #20
sdbimmer
My Ride: 2004 325Ci
You're welcome. Good luck on your fix. For me, I only replace just that one bad sensor. These sensors are expensive, so I only replace just one. It's been running great for the past couple of years. I don't think replacing one bad sensor affected the gas mileage either, so I'm ok with it so far.
