DIY: Cross Drilled Rotor Brake Install! StepByStep - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 32 votes, 5.00 average. Display Modes
Old 10-13-2006, 09:56 AM   #1
5speedsteve
My Ride: gets rid of hickups
Exclamation DIY: Cross Drilled Rotor Brake Install! StepByStep
Yea! More DIY's
This Ones Pretty Easy its 5 bolts per brake and 1 Spring
2 16mm (the caliper to hub)
2 Small Allen Keys (the outer caliper to inner caliper)
1 Smaller Allen Key (the front of Rotor to Hub)
1 Spring (holds in outer pad)
1 Hammer (hit the rotor with the ball side of the hammer)
4 New Zimmerman Rotors
4 New sets of Pads
2 New Brake Sensors (or you can do what I did and splice the wires together)
Car on Lift (you don't need a lift to do this)
Fronts First...Wheels Off
Take out the two 16mm Bolts There on the back of the Caliper
Pry the caliper off (feel free to hit the rotor with a hammer to help loosen things up)
Hit the rotor with a hammer a few times right where this bolt is and then loosen the bolt
Rotor comes off and clean up the hub
New Rotor Goes on and tighten the bolt (see that was easy)
Take the pads out of the caliper and slide two pieces apart (stationary section and sliding section)
Take the two Allen bolts off
Clean em up on the grinder
MMM yummy
Put the caliper on with the two 16mm bolts.
Push the piston back into the caliper (there is a special tool for this but I'm not that special.....so big wrench really does it just fine)
Now put the pads in that piece and put it in place
Now your fresh allens can go back in (theres lil black caps that cover these bolts)
MMM passenger side done!
330xi VF Charged Widebody
5speedsteve is offline   Reply With Quote
Old 10-13-2006, 10:00 AM   #2
5speedsteve
I forgot to Mention the spring goes on the outside you see its there^^^^
The Driver Side is the same Procedure..!....Except theres the Sensor
You can replace it to make your light go out if its worn down really low
or you can cut off the end and splice the wires together. I didn't order one but I probably will later.
Old 10-13-2006, 10:11 AM   #3
5speedsteve
Now the rears are basically the same.
To help get the rotors off I hit them first and lossend the small allen bolt before I took the caliper off.
Now take out those 16mm bolts.
I hit my wrench with the wood part of a hammer to break them loose
After you pry off the caliper Now you can take the rotor all the way off
Clean up the hub.
WTFF okay the e-brake is a drum brake whatever. So you have to adjust the auto adjuster to make it small...Theres a tool to measure the diameter of the shoes then the diameter of you hub to make the right adjustments but we didn't have it so just do trial and error....the rotor is sopposed to fit over the shows snuggly!
Snug
Clean these up again
Put on the caliper with the 16mm's
Compress that piston
Pads in Ready for the allen bolts
Hand tighten then wrench tighten
Spring on the outside and your done
Now the Passenger Side Rear has a sensor. (this sensor was not worn down so we put it back in there...it has a lil clip that keeps it in place.
Old 10-13-2006, 10:17 AM   #4
5speedsteve
So lets make this clear there are 2 sensors Front Driver and Rear Passenger.
Now i was thinkin about doing a DIY: wheel aligment.. but being how the machine and aligment rack cost well over $25,000 its not really a diy job
You start by torquing all your wheels to 80ftlbs. and i put 36psi in the rear and 32 psi in the front
Then on go the sensors
and the rest is history
mmmm
Old 10-13-2006, 08:49 PM   #5
purin
My Ride: 02 330ci
i was thinking about getting rotors off a friend and doing this for the fronts. besides the rotors, there aren't any other required parts like bolts except the tools correct? just like changing out brakes pads? I'm not sure what the sprints you mention are for? Will I see it when i remove the calipers? I think i will give this a try. at least remove and reassemble ^^
thanks for the write up.
-p
purin is offline   Reply With Quote
Old 10-13-2006, 09:06 PM   #6
5speedsteve
there one spring on the outside of each caliper, its just this 5 inch long metal thing that keeps the out brake pad snug, ull see it
i wouldn't recommend putting on news rotors and keeping your old pads....there bound to sqweek....and if the rotors are used i would get them refinished so they have a flat surface to start with
Old 10-13-2006, 09:13 PM   #7
Custom3
My Ride: HellRot 330CI
damn man nice diy...thanks for sharing
Old 10-13-2006, 11:36 PM   #8
purin
My Ride: 02 330ci
the rotors are used but like less than a month and plus his pads that he got at the same time. do you think it will be ok?
Old 10-14-2006, 10:43 AM   #9
5speedsteve
if you keep the same pads on the same rotors you should fine
Old 12-02-2006, 03:55 PM   #10
thumper
My Ride: 2000 328i
thanks for the great write-up.
THEN........................................................ .....................................................NOW
oem......................................................... .....................................................35% tint, clears, BBS RC 18x8.5 w/ Dunlop SP Sport Maxx 225/40/18 and 245/35/18
thumper is offline   Reply With Quote
Old 03-27-2008, 12:22 PM   #11
Mteknic330ci
My Ride: Turbo E36 M3, 335i
Send a message via AIM to Mteknic330ci
Dont forget to pull the cap off the brake fluid housing before you compress the pistons or you will get air bubbles in the line...
-Jake-
SOLD-95' 325i Lightly Modded
Mteknic330ci is offline   Reply With Quote
Old 03-27-2008, 04:25 PM   #12
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Dude, you're two years too late!
Old 03-27-2008, 04:35 PM   #13
JamesH325Ci
What a Pisser
JamesH325Ci's Avatar
My Ride: 2002 325CI
Send a message via AIM to JamesH325Ci Send a message via Yahoo to JamesH325Ci
JamesH325Ci is offline   Reply With Quote
Old 03-27-2008, 08:14 PM   #14
Kmoy2002
My Ride: 2002tii, 540i, 330i
Good one.
Kmoy2002 is offline   Reply With Quote
Old 03-27-2008, 10:37 PM   #15
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
never seen this DIY before.
EXCELLENT write up. I need to do mine asap. I haven't done a brake job in years so it was a good refresher
thanks
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 03-28-2008, 11:32 AM   #16
Mteknic330ci
lol obv, im just noteing for future use of this thread....
-Jake-
Old 03-29-2008, 03:41 AM   #17
5speedsteve
wow i miss my car
Old 04-13-2008, 01:26 AM   #18
sapiro
My Ride: 2001 325i
excellent write-up. PROPS!!!
sapiro is offline   Reply With Quote
Old 04-13-2008, 02:54 AM   #19
jmctype4
My Ride: 330i TiAg ZHP
Originally Posted by 5speedsteve View Post
Two words, boys and girls: USE PROTECTION
Awesome writeup - complements the diy at madrussian.net.
M.
If you didn't earn it, you don't own it.
jmctype4 is offline   Reply With Quote
Old 04-14-2008, 09:06 AM   #20
John_Peters
My Ride: 2001 325i
M.
I have to second this notion. I just did this on saturday, and when I finished my hands looked like I worked in a coal mine.
John_Peters is offline   Reply With Quote
