Thread Tools Search this Thread Rating: Thread Rating: 83 votes, 4.81 average. Display Modes
Old 07-29-2008, 11:54 AM   #81
kpeng
Banned User
My Ride: E46 330 and E30 325
Daddy MO, You will be fine with the Mann or Mahle oil filters, they are basically OEM.
kpeng is offline   Reply With Quote
Old 07-29-2008, 11:58 AM   #82
TrippinBimmer
My Ride: Just Fast!
What if your engine has been treated with the 15k mile oil change for the first 45k miles of it life? Is there any thing u can do to clean up the gunk inside the motor? I am planning on changing to Mobil 1 0w-40 every 5k.
Anthony
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 07-29-2008, 12:50 PM   #83
kpeng
Banned User
Have you tried Seafoam? Use some before each oil change.
Old 07-29-2008, 01:02 PM   #84
tony325ci_51
My Ride: BMW 335i 2007 Coupe
Nice Ken,
Just to add that if you're doing your own maintenance there's plenty more you should check, some frequently, some less often, a quick browse through the Inspection 1 and 2 schedules will probably highlight some items that may otherwise have been ignored by the DIYer. Don't be too daunted, mostly it just involves visual inspection, that is, just looking at things.
http://www.pelicanparts.com/bmw/tech...check_list.htm
A load more useful info here:
http://www.bimmerfest.com/wiki/index.php/BMW_E46
Not forgetting our very own superb stickied (all newbs should read before asking questions):
http://forum.e46fanatics.com/showthread.php?t=320965
Great references for finding part numbers here:
http://www.realoem.com/bmw/
http://bmwfans.info/original/
tony325ci_51 is offline   Reply With Quote
Old 07-29-2008, 01:03 PM   #85
TrippinBimmer
My Ride: Just Fast!
Just dump it in the crankcase right?
Alpine White M3
MaximumPSI Stage4
Old 07-29-2008, 01:04 PM   #86
Snik
Snik's Avatar
My Ride: IR M3 Vert.
hahhaa, Ken that looks a lot like Mike Millers write up.
you left out the radiator and expansion tank, and thermostat. VERY IMPORTANT
i got 155k mile sout of my oe radiator, i just changed it last saturday. im not sure if i had the oe expansion tank
i have 155k miles + on my oem vlve cover gasket and not one leak.
i do have a leaking ps hose that runs from the res to the pump.
ps pumps do go bad, but with flushes like you say, you should last.
clutches tend to go at around 15k, mine has a slight slip right now, has had it since around 140k.
control arms, look for about 60-70k out of the stock ones, before the call joints go to sh1t. then then CAB.
diff bushings on aggressively driven stick shifts are usually good for about 130k
BMWs 1st wp update was to a metal, alu alloy looking pump, they have now switched back to a plastic type pump.
i have a alu wp that i took out last saturday and it is in immaculate condition, no play no rust except on the pulley side, hard to believe i got almost 80k miles out of it. the one i replaced it with was a heavier one, much bigger impellers about twice the OEs width, bavauto sells it for about $45
Do you ride a sportbike?
Old 07-29-2008, 01:10 PM   #87
Snik
Snik's Avatar
wrong, they are not OE. but approved OE suppliers.
mann filters come from 2 places mexico and germany, ive heard quality control on the mexican ones are not as good.
i just bought a box of 10 mahle filters and called it a day. mahle filters are 100% germany
i believe i payed like $60 shipped for the box.
Old 07-29-2008, 01:11 PM   #88
Snik
Snik's Avatar
Anthony
you shouldnt have that much gunk at 45k miles, just doing 6-7k oil changes from hear on out run good gas, and air filters, and you will be fine.
Old 07-29-2008, 02:09 PM   #89
BMWilli
G-cool, G-smooth, G-style
My Ride: 323 Ci
the link to replacing the power steering fluid also shows how to clean maf sensor.
how often does the maf sensor have to be cleaned?
BMWilli is offline   Reply With Quote
Old 07-29-2008, 02:12 PM   #90
BMW04E46
My Ride: 2004 325Ci SMG
2005 Acura TL A-Spec
2004 325Ci SMG M-tech II (Sold and got 2005 Acura TL A-Spec) :-(
2002 530i Sport
1997 Mercedes Benz C280 Sport (Sold and got 2002 530i Sport!) :-)
2007 Yamaha VX Cruiser (WaveRunner)
see my garage for pics
How a Rogue IKON should look on a M-Tech II Coupe
http://forum.e46fanatics.com/showthread.php?t=537372
BMW04E46 is offline   Reply With Quote
Old 07-29-2008, 02:37 PM   #91
nX07
My Ride: 01' 325i black/tan
Do it as soon as possible. You should still be ok. Any significant amount of time longer, and you run the risk.
In regards to changing the ATF; it I am lets say at 70,000mi and I haven't changed the ATF, and I can't risk changing it now.. what happens? Just hard shifting?
I'm no where near 70,000mi but I'm just wondering..
nX07 is offline   Reply With Quote
Old 07-29-2008, 06:05 PM   #92
kpeng
Banned User
I didn't say they were OEM, I said they were like OEM. I'd recommend buying the packs from Tischer.
Old 07-29-2008, 06:13 PM   #93
CJeansonne
My Ride: 2000 323i
how much seafoam should i use to treat before each oil change and where do you dump it in at...ive done it for the fuel system through the gas tank....??? TrippinBimmer mentioned putting it in the crankcase???
CJeansonne is offline   Reply With Quote
Old 07-29-2008, 06:18 PM   #94
WhiteOut323i
My Ride: 2000 323i
comin through as always!!!
good Shi7 boy
WhiteOut323i is offline   Reply With Quote
Old 07-29-2008, 06:34 PM   #95
brodaiga
My Ride: 330ci
kpeng,
i always though we should use Mobil One 0W40 European Cars for our cars. It is the only mobil one oil approved by bmw on the back of the container. it is what I have been using.
brodaiga is offline   Reply With Quote
Old 07-29-2008, 06:52 PM   #96
tony325ci_51
Nothing wrong with that. That's exactly what BMW say you should be using.
Old 07-29-2008, 06:54 PM   #97
kpeng
Banned User
I would put a 1/2 in the crank, and 1/2 through a vacuum line (usually the brake booster line)
Old 07-29-2008, 07:01 PM   #98
tony325ci_51
Power Steering Fluid - Every 50,000 miles
Very neglected, most people wouldn't even bother. In fact, I know people who have ran on the same fluid for over 100,000 miles. It may or may not make a difference, but it's very inexpensive to do, and why not give your baby some fresh fluid? Our cars take ATF fluid instead of Power Steering Fluid. I used the Royal Purple ATF, but Mobil 1 will do too. Don't get the cheap stuff, make sure it's Dextron III approved. I've read instances where people have gone over 200,000 miles on the original rack & pinion/power steering pump by changing their fluid on a regular basis. You can bleed it by opening up a line, but I just use the turkey baster technique
Quick tip, when doing this jack front wheels up off the ground to make steering easier to turn, ease strain on PS components and save tyre "scrub".
Old 07-29-2008, 07:05 PM   #99
Born Again
Born Again's Avatar
Location: Tis quite a statement. Where do you live - where do we all live? in our minds? our souls? our bodies?
My Ride: She aint much 330ci
nice kpeng - the mods should be so happy to have such a stellar and upstanding forum member on the board
best mod to date : OEM grocery bag holder
Originally Posted by Zell View Post
E46Fanatics - the Honda community of gun owners. Keep staying classy, I'm sure you all are going to be excellent examples of how to keep gun rights from being infringed. :facepalm:
Born Again is offline   Reply With Quote
Old 07-29-2008, 08:35 PM   #100
shortyb
My Ride: Has blue lights
Anthony
You should be fine. Look at this guy's after 92K on 15K+ change intervals.
http://forum.e46fanatics.com/showthr...980&highlight=
Save your $$$ on the Seafoam, you probably won't need it. If you do decide to use it, be careful, it's a very aggressive cleaner. Change your oil soon after it's use. Aggressive cleaners can do more harm than good if used too much.
shortyb is offline   Reply With Quote
maintenance, propaganda, tool
