Old 06-11-2008, 04:35 PM   #1
JetBlackE46
Modded
My Ride: E36/E46 M3 E46 323
LED Tail Light question
I believe that aftermarket kits use resistor boxes to avoid the bulb failure light by "fooling" the LCM module. I'm concerned about the resistor boxes getting too hot and potentially starting a fire or melting something.
Anyways, I was wondering if I bought aftermarket LED tails and did the dealer reflash, could I NOT use the resistor boxes???
JetBlackE46 is offline   Reply With Quote
Old 06-11-2008, 06:08 PM   #2
neil1138
yes
neil1138 is offline   Reply With Quote
Old 06-11-2008, 06:20 PM   #3
Owtlaw333
My Ride: 2009 Mazdaspeed 3 GT
Depends on the year of your car.
I'm also gunna guess that you will still need some regardless since LEDs in general require completely different amounts of power to your stock setup. That's something reflashing won't solve.
Bringing it back for the new people...
productionof1.com
|||_Buy my photos?_|||
Owtlaw333 is offline   Reply With Quote
Old 06-11-2008, 06:35 PM   #4
JetBlackE46
Modded
Originally Posted by neil1138 View Post
yes
do you know of anyone that has done this? please point me in the right direction as i'm considering this.
thanks
Old 07-24-2008, 08:02 AM   #5
Biz
My Ride: is clean.
Any update on this? I have the same concerns and would like to upgrade to LED tails without using resistors/load equalizers.
Stock: 2002 M3 Coupe | 6MT | Cold Weather | H/K Audio | Xenons
Mod: OEM ZCPs | RE Spacers 15F/10R | Huper Optik 30 | DICE Silverline | ZHP Knob | Clutch Stop | Grocery Gripper
Biz is offline   Reply With Quote
Old 07-24-2008, 11:48 AM   #6
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
I have never tried this but the resistors are entirely insulated and do not heat up so you don't need to worry about running them in the trunk.
Old 07-30-2008, 01:06 AM   #7
adrianpl
My Ride: 01 330ci
i need resistors for my car because i have leds instaled for the rear lights but they blink and on the inside it comes up on the panel. anyone know what resistors i need?
adrianpl is offline   Reply With Quote
Old 07-30-2008, 10:54 AM   #8
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Do you have OEM or aftermarket tails? If they are OEM, you will need to go through an LCM retrofit to get them to work properly.
Old 07-31-2008, 01:34 PM   #9
Nelson
Nelson's Avatar
My Ride: Alpin weiß ///M
Not necessarily. Depends on the build date of the car. My car did not require a new LCM.
///M
| eBay mod'ing sUUCks
Nelson is offline   Reply With Quote
Old 07-31-2008, 07:08 PM   #10
adrianpl
My Ride: 01 330ci
its a 2001. aftermarket. http://www.jlevistreetwerks.com/p217...duct_info.html. i need this
