Sponsored by BimmerWorld
Old 08-07-2008, 12:44 AM   #1
BET325
My Ride: 2004 325 CI
coilsovers
i would like some suggestions from fanatics as to what coilover kit to go with. im looking for a mild firm/sporty ride that would be comfortable as a daily driver. any suggestions???
BET325 is offline   Reply With Quote
Old 08-11-2008, 11:15 PM   #2
Chris-TK
My Ride: Mk VI GTI
KW Variant 1 coilovers sound like the best for you. I've got a set and LOVE them. Great ride and feel. Teins will most likely be too harsh for what you're describing. You could also go with a Bilstein PSS, PSS9 or PSS10 setup. The KWs are a bit more expensive than the Bilsteins.
K.
Chris-TK is offline   Reply With Quote
Old 08-12-2008, 04:55 PM   #3
nleksan
My Ride: 328Ci, 325i, M3 ZCP
Send a message via AIM to nleksan
Go with Suspension Techniques Variant1!!! They are the same exact thing as the KW V1's (except galvanized rather than stainless steel), are cheaper, and are the perfect coil-overs for daily-driving, as they increase your handling phenomenally, but don't significantly degrade ride quality. They have my full support!
(Temporary Sig)
- DPE - Volk - BBS - OE CSL - JRZ Race 4Way -
- M-Tech II - RE - AP Radi-CAL -
- Hotchkis - AFE - AKG - KW CS 4way -
- TMS - OS Giken - SS V1 - Vorsteiner - Recaro - Focal - JL - MORE! -
GARAGE:
-00 328Ci Topaz 6MT ZSP/ZPP/HID (Street) ESS TSE2+ 2980lb
-01 325i TiAg 5MT/ZSP/ZCW (Street) Track Susp/Brk/Whl 3102lb
-06 M3 AW/IR 6MT/ZCP/HID (Dual-purpose) NA Fully-Built 2810lb
nleksan is offline   Reply With Quote
Old 08-12-2008, 05:01 PM   #4
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Have Bilstein pss9s set low enough to remove wheel gap and on their most comfortable setting. In doing so, it looks "just right" but is more comfortable on bumps and potholes than oem sport suspension IMO
Timeless Motor Group
Old 08-16-2008, 02:55 PM   #5
BET325
kwv1 are comfortable enought to be a daily driver??? ive heard they are one the aggressive suspensions???
Old 08-16-2008, 03:12 PM   #6
f0kai
My Ride: 2003 BMW 320i
i'm running PSS10s and they ride quality is as good if not better than oem
f0kai is offline   Reply With Quote
Old 08-16-2008, 03:48 PM   #7
Brian N
My Ride: 2001 330i Jet Black
Nah they aren't that aggressive. They are a great coil though, I hear some people say ride quality is on par with stock. Some even say better. Plus you can drop to the floor almost, and you can go wrong with their lifetime warranty.
Brian N is offline   Reply With Quote
