Old 08-12-2008, 08:35 PM   #1
neil1138
Post Ok, I'm about to have one crazy DIY weekend
Ok, I have decided to go all out and repair all of my problems. Here's what's going to hapen this weekend:
Control arms
control arm bushings
Meyle RSM's with Z3 reinforcement plates
Diff bushings
I have done the following repairs since I bought the car 1 year ago:
spark plugs
air filter
oil change
fuel filter
brakes and rotors
radiator
VANOS seals
Serpentine belts
Valve cover gasket
Brake fluid flush
Subframe repair
H&R Cup Kit (not really a repair, more of an upgrade)
What else should I do while I'm at it? I want to get the car running perfect before school starts so I dont have to worry about anything. Tell me everything. Thanks
neil1138 is offline   Reply With Quote
Old 08-12-2008, 08:52 PM   #2
weisiong123
My Ride: 323ci
Neil...didn't you have a similar thread....listing those above...may be repetitive bro...good luck tho
weisiong123 is offline   Reply With Quote
Old 08-12-2008, 09:29 PM   #3
neil1138
not really, I had a thread that asked about my hesitation problem and one that asked about my strut mounts. Now im making one that asks for opinions on what I should do while my car is up on jacks. No point in just making another post in one of my existent threads only for the thread to just fade away. It gets annoying when people ask for help and nobody replies cause they are too busy replying to threads about killing lambos. Jeez man, I have already searched for answers and I just need recommendations.
If you have any, please feel free to tell me rather than shutting me out
Old 08-12-2008, 09:37 PM   #4
smolck
My Ride: 2004 ZHP Sedan
I'd add sway bar end links to the list as the front can wear out and break (as mine did). Other than that I think you have all the front end stuff covered.
Check out my BMW Blog
http://smolckbmw.blogspot.com/
Check my Youtube channel for DIY's and fun stuff
http://www.youtube.com/user/flipfinish?feature=mhee
smolck is offline   Reply With Quote
Old 08-12-2008, 09:40 PM   #5
neil1138
Hey thanks for the heads up man, I'll add that to my list. What place has the best endlinks? Should I go OEM? I will need them by Friday so I have to get them with fast shipping!
Old 08-12-2008, 10:03 PM   #6
smolck
If you need them by Friday you are looking at having to get them locally. I see them on ebay all the time for like $30 a set. Maybe you could do that and pay for overnight shipping. You'll still save over dealer prices, they charge $60 each here...
Old 08-12-2008, 10:07 PM   #7
//TRD power
My Ride: 3.0 | 200hp | 214trq
final stage resistor if its giving you slight problems, itll just crap out on you when you most need it.
//TRD power is offline   Reply With Quote
Old 08-12-2008, 10:09 PM   #8
smolck
I think he was talking about stuff as it relates to front suspension, not random stuff.
Old 08-12-2008, 10:23 PM   #9
KriTiKaL AspecT
My Ride: 2001 AW 330Ci
looks like you have your work cut out for ya!
What differential bushings are you using? and where did you buy at?
One other thing I could think of is your tie rods. But I'm sure you would notice that (steering play).
Headers - KW V2 - Hotchkis Sways - 55w 6000k HID - 35w 6000k HID fogs
EVO 3 SSK mit ein DSSR - EE Tails - Meyle LCA, FCAB, & RTAB w/ Rogue Limiters - M3 Mounts ....
-Paul
KriTiKaL AspecT is offline   Reply With Quote
Old 08-12-2008, 10:29 PM   #10
//TRD power
hmm I dont see anything about him saying suspension unless im missing it
Well, not everything he listed was suspension either, sparkplugs and air filter. Anyways, FSR is a gud thing to look for if you got some use and abuse on it.
Old 08-13-2008, 12:59 AM   #11
neil1138
I'm open to all ideas, it's cool. Thanks for the heads up on the FSR, the symptoms are erratic fan speeds right? I might have to look into that. Any other suggestions?
About the swaybar endlinks, can't I order them from a sponsor and get 2nd day shipping or something like that? I hope that is an option because this weekend is the last one before school starts.
Btw... The diff mounts are OEM.
Old 08-13-2008, 07:59 AM   #12
W///
My Ride: E30, E46, E92 M3
Have you thought about doing a coolant system overhaul? I'm envious of you as I don't have the skills to do everything you have planned on my own, but that would be a very good investment. Your car will be running like new. Good luck!
W/// is offline   Reply With Quote
Old 08-13-2008, 09:32 AM   #13
Miko_10
My Ride: 330i 5 Spd
check your intake elbow tube for cracks if you still have your hesitation problem. depending on how many miles you have do an Inspection I or II and use this as a guide. good luck..
http://forum.e46fanatics.com/showthr...553&highlight=
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 08-13-2008, 10:37 AM   #14
ssm1991
My Ride: 2004 325i
... Diff bushings
Be sure to rent the proper tools, or else you may not be able to finish it.
ssm1991 is offline   Reply With Quote
Old 08-13-2008, 10:47 AM   #15
bigfatvr6prik
My Ride: Z8
Diff Bushings, better have proper tools. Diff bushings in my opinion is one of the more challenging diy's.
bigfatvr6prik is offline   Reply With Quote
Old 08-13-2008, 11:29 AM   #16
n2Bimmer
My Ride: Loves Corners
you should have replaced the end links when you did the H&R's, but better late than never. Good luck, im going to have a long DIY myself too.
Old 08-13-2008, 11:47 AM   #17
ModBargains
ModBargains's Avatar
My Ride: M3
+1
Nothing is worse than having to stop to go get the tool you need. When you get back, you can't remember where you left off! Definitely make sure you have everything you need before you even consider jacking up the car
Blake Brunner|blake@ModBargains.com|(714) 582-3330 ext. 8011
We Specialize In:
BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts | BMW Tail Lights |
BMW Wheels | BMW Intake
Hours
Check out our Blog for updates!
ModBargains is offline   Reply With Quote
Old 08-13-2008, 11:51 AM   #18
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
Depending on ur milage, u should be doing water pump and thermostat. Radiator and expansion tank also go on these cars, and should be replaced before 100k. I'll be doing the latter in the spring, and did the WP and tstat at 70k.
-Brendan
Old 08-13-2008, 12:23 PM   #19
neil1138
Yeah, I know it's about time to replace my thermostat and waterpump. I have already replaced my intake boot so that's good.
Old 08-13-2008, 12:56 PM   #20
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Would you want my brand new e36 M3 endlinks? I'll overnight them if you want.
hi its me alec is offline   Reply With Quote
control arm, diy, oil, vanos
