Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
My Ride: '13 AW F10 535i
so there's something wrong with my suspension :pics:
So for the past month or so the front right side of the car has been making this terrible noise. I assumed it was the suspension but as I would push down on the car it seemed as though the noise was coming from behind the wheel. So I took a lot of pics so that maybe some one could spot what is wrong. TIA
Oh and I sometimes feel it under my feet on the drivers side... ![]() ![]() ![]() ![]() ![]() ![]() ![]()
ERnie
2001 330i Steel Blue e46 "Vanessa" [retired] 2011 335i AW e90 "Zoey" [retired] 2013 535i AW F10 "Lola" ![]() "Losers always whine about their best, winners go home and f*** the Prom Queen."-John Mason Last edited by shockin330i; 08-13-2008 at 09:48 PM. |
#2 |
ERnie
2001 330i Steel Blue e46 "Vanessa" [retired] 2011 335i AW e90 "Zoey" [retired] 2013 535i AW F10 "Lola" ![]() "Losers always whine about their best, winners go home and f*** the Prom Queen."-John Mason |
#3 |
Foot!
4ngie likes this. |
#4 |
ERnie
#5 |
Yes, but did you know it would be me?
4ngie likes this. |
#6 |
Big toe!
![]() -Jorge All low no go |
#7 |
ERnie
#8 |
Thread failure
ERnie
#9 |
Here are some sound clips...
[URL=
ERnie
#10 |
i think it's a shock... sound clip sounds like something hydraulic to me and something about the ruber boot over the shock doesn't look right to me
-dale
![]() e46 SOLD :( |
#11 |
My Ride: 2001 3 Pedal M54b30
Maybe its a blown shock? If your pushing down on your car and it has a lot of movement(sounds like it does) it could just be them bottoming in out.
#12 |
Your control arm bushing pulled apart. The inner part that is connected to the arm itself should be flush with the outer piece in the carrier that is bolted to the car.
#13 |
These two pieces should be flush or the thing is going to move all over the place.
#14 |
Ah, I'll have to look into that
ERnie
#15 |
The R1 makes it fun
What elite53 said is true and that can be dangerous during hard cornering.
#16 |
I'm just wondering what's making that awful noise....
ERnie
#17 |
The end of that control arm banging around. Reach under there and grab the end of it with your hand and move it around and you will see what I'm talking about.
#18 |
nice!
Performance: Dinan Stg 3, Dinan Perf Tranny Software, Dinan High Flow Throttle Body, Dinan High Flow Intake, UUC TSE3~TMS Power Pulleys
Suspension: Eibach Sportlines, Koni Sports, Ground Control RSMs, Dinan Strut Brace, Eibach Sways, Ground Control Endlinks, Poly RTABs Exterior: Painted Kidney Grille, BSM Roundels, Clear Sides, Corners, & Tails, 3M Tint 20% Rear, 35% Front, Halogen to P46/AE Wheels: Staggered 19" V710s on T1Rs |
#19 |
Similar situation
Not getting noise but front end seems quite loose, I'm getting bad steering response at speed and a breaker bar on the driver's side lug nuts shows quite a bit of front to rear movement of the wheel. Took the front wheels off and moved it by hand.....loose where the control arm enters the bushing on the frame.
It does not look close to the photo on this thread....driver's side is really bad, pass side a bit better as far as play goes. So the question now is what to do? Replace with OEM mounts? Replace with aftermarket? I assume I need to remove the control arms to do the replacement, should I get new arms? BTW the car only has 26K on the clock.....I don't get why they are shot, but I assume they are! Thanks for any opinions.......
Mike In Mass ![]() |
#20 |
My Ride: 2001 AW 330Ci
Time for new control arms. Do a little research there is tons of info here. Many venders carry them check modbargians.com.
My car is '01 with 45,000 when I got it. Bought it off a couple in Oklahoma who had recently moved from Connecticut. My bushings are fading fast I'm guessing the NE winter took its toll on the rubber (not that the rubber is that good anyways), plus the age. I must of made it this far because it was a summer car for them. However, 60,000 is about the time these things start failing.
![]() Headers - KW V2 - Hotchkis Sways - 55w 6000k HID - 35w 6000k HID fogs EVO 3 SSK mit ein DSSR - EE Tails - Meyle LCA, FCAB, & RTAB w/ Rogue Limiters - M3 Mounts .... -Paul BSME |
