Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
H&R Cupkit fitment with CSL wheels??
can i fit 18" csl with H&R cup kit?
#2 |
Do you have a coupe or sedan? Yes if you get the correct offsets and tires. Max tire width for a sedan is 255 and a coupe is 265. Are you getting a square setup, if so then 18x8.5 40mm offset will work perfectly. If you are going staggered with a 9.5 rear and a 255 or 264 you might need to roll your fenders.
btw...Worst thread topic title ever.
K. |
#3 |
'a certain moderator'
as long as u get wheels that are made for non-M, yes.
2nd, awful title. fixed for the n00b.
#4 |
Yes they will fit. I've personally had that setup before. If you have the right offsets and tire sizes you shouldn't have a problem. If you decide to do a staggered setup, you might have to roll your fenders to avoid rubbing with 2-3 people in the car.
#5 |
1.888.JLEVISW
Yep you can run that setup so long as you have rear ET45 wheels and nothing larger than a 255 rear tire.
#6 |
I have this cupkit and CSL 19's in the rear. i rub a little bit with fenders rolled, but I have 265's in the rear. 18's should be fine.
