Thread Tools Search this Thread Rating: Thread Rating: 496 votes, 5.00 average. Display Modes
Old 09-06-2008, 01:52 AM   #1
Dreamliner330
My Ride: 330xi
Free mods / cheap mods under $10 DIY
THREAD PURPOSE: To collect all information for e46 free mods
THREAD DEFINITION: Free mods defined as: UNDER $10 (excluding any fluid replacement) sometimes a mini-budget is good...
THREAD RULES: Do NOT double post a MOD, do NOT comment on mods...just LIST EM'
THREAD STRUCTURE: I would like you all to adhere to the FOLLOWING ORDER:
MOD NAME
MOD COST
MOD BENEFIT
MOD DESCRIPTION (PICS OR FAIL)
MOD LINK (other sites/threads that contain a comprehensive DIY or provide more info)
Go Team e46Fanatics!
Dreamliner330 is offline   Reply With Quote
Old 09-06-2008, 01:52 AM   #2
Dreamliner330
My Ride: 330xi
MOD NAME: Golf Tee Mod
MOD COST: FREE, $0.00
MOD BENEFIT: More low rpm 'rumble' exhaust note.
MOD DESCRIPTION: Remove vacuum line that closes a metal 'butterfly' valve. plug removed vacuum line with a golf tee or similar.
In the picture below you will see a metal butterfly valve in the right exhaust pipe, immediately above this is a rubber hose that connects to it. Nothing needs to be done on the exhaust side, as it will just stay open now.
This is the rubber hose that you pulled off of the exhaust, you can see I plugged the hose with a wire crimp.
MOD LINK
http://forum.e46fanatics.com/showthread.php?t=585653
http://forum.e46fanatics.com/showthread.php?t=520094
MOD NAME: Clutch Delay Valve (CDV) Delete
MOD BENEFIT: Smoother Shifting (Manual Transmission Only).
MOD DESCRIPTION: Remove an inline restriction valve that "limits" clutch slip for newbie's but is a major PITA for everyone else...(not in all e46's)
...CDV removed...
MOD LINK
http://m3.madrussian.net/diy_cdv.shtml
MOD NAME: Clutch Stop Mod aka Perfect Clutch Stop
MOD COST: <$5.00
MOD BENEFIT: Less Clutch Travel, Faster, Shifting (Manual Transmission Only).
MOD DESCRIPTION: Screw in a 1.5" elevator bolt with a adhesive furniture leg pad in place of stock clutch stop.
Clutchstop installed:
MOD LINK
http://forum.e46fanatics.com/showthread.php?t=206363
MOD NAME: Custom CAI
MOD COST: >$3.00
MOD BENEFIT: Colder/Free Flowing Air, Better MPG's
MOD DESCRIPTION: Cut 2" hole in bottom of air box, run flexible tube from air box to bumper cavity.
Tubing Installed:
MOD LINK
http://forum.e46fanatics.com/showthread.php?t=596255
Old 09-06-2008, 03:12 PM   #3
zach113092
Banned
My Ride: 2003 bmw 330ci
Mod name: debadge
Mod cost: free
Mod benefit: looks good
Mod description: use credit card and slide underneath each letter or number, removing the "badge" then use goo gone or alcahol wipes to remove the remaining gunk, whatever you use to take off the gunk wipe it off as soon as your done using it because its probably not that great for you paint.
Mod link:http:
//forum.e46fanatics.com/showthread.php?t=594465&highlight=debadge
zach113092 is offline   Reply With Quote
Old 09-07-2008, 06:40 AM   #4
DOB2009
My Ride: 325i
Nice thread keep it coming. I'm painting Kidney grills and pillars for less than $10, sandpaper, matte black bumper paint, and primer. I may also re-paint the mirror housing.
DOB2009 is offline   Reply With Quote
Old 09-07-2008, 11:16 AM   #5
kpeng
Banned User
My Ride: E46 330 and E30 325
Damn, you beat me to it. I was going to make a "Kpeng's 10 low-cost/free mods" thread.
kpeng is offline   Reply With Quote
Old 09-07-2008, 11:22 AM   #6
bryan3091
My Ride: 2001 300xi
/subscrizzled...
but i'm still a little confused about the golf tee mod...
~bryan3091~
bryan3091 is offline   Reply With Quote
Old 09-15-2008, 05:26 PM   #7
adrianpl
My Ride: 01 330ci
Originally Posted by bryan3091 View Post
/subscrizzled...
just look at ur exaust. theirs a rubber hose. unplug it. stuff it with a screw
adrianpl is offline   Reply With Quote
Old 09-15-2008, 06:53 PM   #8
watchbuff
My Ride: 2005 330Ci
I have to post something here to subscribe.
Cant think of a cheap mod. Cheap and BMW are not in the same league
Fast and the furious wanna-be's are always good for a laugh at the "Green light Grand Prix" .
watchbuff is offline   Reply With Quote
Old 09-15-2008, 11:33 PM   #9
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
i have never heard or seen my valve in my exhaust close. and i have tried everything to see it close
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 09-16-2008, 01:56 AM   #10
paraklas
My Ride: ESS TS2 320ci
MOD NAME: E90 Vanity Lights Swap
MOD COST: $2.00 (Lights from ebay)
MOD BENEFIT: Better looks
Before:
After:
My DIY Link
MOD NAME: Trunk Light mod
MOD COST: $3.00 (Lights from ebay)
MOD BENEFIT: More light for the people who actually use their trunk
DIY Link
MOD NAME: Alarm Shock Sensor install
MOD COST: $10.00
MOD BENEFIT: Increase the functionality of OEM Alarm
DIY Link
MOD NAME: Restoring rubber seals with silicone grease
MOD COST: $4.00
MOD BENEFIT: Restoring rubber seals
DIY Link
Old 09-16-2008, 02:11 AM   #11
Dreamliner330
My Ride: 330xi
MOD NAME: Valentine 1 Hard wire ***Only if you already have any radar detector.
MOD COST: Varies...$0 if you have a V1 ($0 also if you have a escort and a phone cable)
MOD BENEFIT: Mod shows a simple place to retrive 12v & Ground for windshield/mirror mounted devices.
MOD DESCRIPTION: Pull down overhead light/sunroof control panel, tap secondary power cable lead.
MOD LINK
http://m3.madrussian.net/diy_valentine_v1.shtml
Old 09-16-2008, 04:54 AM   #12
Wezza
My Ride: 2004 318i Sport
Originally Posted by zach113092 View Post
Mod name: debadge
Mod cost: free
Mod link:http:
Thin fishing line is also good to use to take the old badges off with.
Wezza is offline   Reply With Quote
Old 09-16-2008, 08:46 AM   #13
Titanium 325
My Ride: '01 325Ci
Dental floss works good also. Clay bar to remove excess residue, or adhesive remover spray. Either works great. Then wax/polish the affected area to ensure that the water beads even and not in the shape of the old lettering.
Mods - M3 Style Lip Spoiler, ACS Replica Roof Spoiler (bowed in the middle), Predator Chromium Angel Eyes, P46 Xenons, Smoked Side, Corners and LED Tails, Blacked out Kidney Grills, Self Painted Bumper Reflectors, K&N Drop-in Filter, 19" Miro M6 Reps in Time Attack
Titanium 325 is offline   Reply With Quote
Old 09-16-2008, 08:49 AM   #14
Titanium 325
My Ride: '01 325Ci
Mod - Painted Reflectors
Mod Benefit - cleaner looking appearance
Cost - about $10 total for paint, primer and clear.
Difficulty - Easy, just takes time.
Painting the stock front and rear bumper refelctors vs. paying close to $100 for a set (front and back, or $60 for fronts).
I used Metailic Silver for mine. Did three coats of primer, 4 coats of color and 3 coats of clear. Not an exact match, but pretty close. The more Zanio (polish as they are now painted as well) I put on them with the rest of the car, the closer they match.
Old 09-16-2008, 11:38 AM   #15
adrianpl
My Ride: 01 330ci
keep this forum going.. good stuff
Old 09-16-2008, 02:15 PM   #16
grogers
My Ride: 2001 330Ci
Wow, I'm so glad I read this. Turns out my butterfly valve was so covered in soot it was NEVER opening! I had to jab it with a screw driver to get it to move rumble=
grogers is offline   Reply With Quote
Old 09-16-2008, 05:28 PM   #17
Zlatty
My Ride: '13 VW GTI
This is a fantastic thread .... I love it
Zlatty is offline   Reply With Quote
Old 09-16-2008, 05:35 PM   #18
JJR4884
My Ride: BMW
Subscribing
Sorry but I am at work, but I would like to mention the Red Needle Mod
Cost... a red sharpie, so $2 est?
All in all, take your instrument cluster out, then apart, color them evenly and carfully, several coats, put it back on, best 30 minutes you've ever spent
I'll try and edit this later to keep it in format with the rest
JJR4884 is offline   Reply With Quote
Old 09-17-2008, 11:34 AM   #19
tonee
My Ride: BMW 320Ci, GSX-R1000
So what was the initial purpose of the butterfly valves being closed? now that we're opening them permanantly, will it effect anything?
Also will it work on 320s?
tonee is offline   Reply With Quote
Old 09-17-2008, 01:19 PM   #20
paraklas
Less noise during low rpm. The 320 doesn't have the flap
